TowRig.com
Go Back   Diesel Forum - Cummins, Duramax, Powerstroke & Towing Forums > Dodge Specific Tech Forums > Dodge 2nd Gen Cummins 5.9 (12v)
Sponsors
Reply
Thread Tools Display Modes
  #1
Old Posted 04-10-2012, 02:10 PM
codyk68 codyk68 is offline
new to site stumbling around
I bought a 1996 12v 5.9 w 250 k on odo. I was getting 11 towing and 13 allaround mileage with a 4 in exhaust took it to mech to adjust timing and other things he adjusted timing and it ran horrible when I test drove it in less than a mile it had a spontaneous overheat which caused the truck to quit running acted as if starved for fuel or partiallyclogged filter blew out side of radiator and wouldnt start. He said 5 cylinders are around 150 lbs compr. and one at 340 can anyone give advice.
thanks
cody
Sponsors
  #2
Old Posted 08-20-2012, 11:19 PM in reply to codyk68's post "new to site stumbling around"
Diesel Nut's Avatar
Diesel Nut Diesel Nut is offline
Send a message via AIM to Diesel Nut
You have a mess of problems. My guess is a bad head gasket first off. Low compression on 5 cyl and a blown out rad and overheating lead me to believe that. Since you didn't have the issues before the timing my guess he either he bumped it too far or the increase was enough to kill it. Advancing timing increases cylinder pressure. Things get worse if the guy doesn't really know what he's doing. Fortunately, a head gasket and some studs should fix your issues there. If there is a major problem in the bottom end you'll know when the head is off. Obviously you need a radiator.
Where did he set the timing? What else did he adjust?
Reply
Bookmarks
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
