If your intercooler boots have oil on the inside of them, it is due to the crankcase ventilation system putting oil back into the air flow. A very common problem with the PSDs. The typical fix is to clean out the intercooler boots with a carb cleaner, or starting fluid, just something to get the oil out. Then do the "CCV mod" to get rid of the oil contamination inside the intercooler and associated piping. Search over on thedieselstop.com for more info on the CCV mod.
__________________
99 F350 XLT, CC, DRW, 4x4, Cummins 12V powered with 370s, 191DVs, #10 plate, Super B turbo, 12mm head studs, ATS manifold, 4kGSK, 6spd w/ CON FE, Rickson 19.5s with Michelin 245/70R19.5 XDE MS, 5" exhaust, Hellwig Air bags, Edge Leveling Kit, Prodigy Brake Controller, 2 12" Kicker Comps, Delta Toolbox
05 F250 XLT, SC, 4x4 V10, 6spd, 17" Lariat Rims, Integrated Brake Controller, 4.10 LS
