TowRig.com
Go Back   Diesel Forum - Cummins, Duramax, Powerstroke & Towing Forums > GM Specific Tech Forums > GM Duramax 6.6 (LLY)
Sponsors
Reply
Thread Tools Display Modes
  #1
Old Posted 10-27-2005, 01:30 PM
budkole's Avatar
budkole budkole is offline
Duramax normal operating temp
Does anyboby know the optimal "normal" operating temp of the duramax and are the different versions the same temp also, lb7, lly, lbz
Sponsors
  #2
Old Posted 10-27-2005, 02:00 PM in reply to budkole's post "Duramax normal operating temp"
miniwally's Avatar
miniwally miniwally is offline
When I have my Predator hooked up I usually see around 190 to 195 for normal temps.
I have noticed that my milage isn't as good when the engine temps are low.
I'm no expert but I would guess optimum temps would be near 190
  #3
Old Posted 10-27-2005, 02:23 PM in reply to miniwally's post starting "When I have my Predator hooked up I..."
BadDog's Avatar
BadDog BadDog is offline
TRC Staff
Yeah, mine never crosses 200 even with the chip AND ambient over 110.
__________________
2002 Dmax/Allison CC 4x4 SWB Juice/Attitude, 65 gallon tank, 30k goose/5er, 33" ATs
  #4
Old Posted 11-07-2005, 08:29 AM in reply to BadDog's post starting "Yeah, mine never crosses 200 even with..."
Burt4x4 Burt4x4 is offline
The gage for mine is about 200-205 all the time..my tranny looks like about 150-160...
  #5
Old Posted 11-07-2005, 08:55 AM in reply to Burt4x4's post starting "The gage for mine is about 200-205 all..."
PermanentMarker's Avatar
PermanentMarker PermanentMarker is offline
TRC Staff
Send a message via ICQ to PermanentMarker Send a message via AIM to PermanentMarker Send a message via MSN to PermanentMarker Send a message via Yahoo to PermanentMarker
My lb7 usually goes around 190. Hottest I ever saw was NB Cuesta Grade (101 north of San Luis Obispo) at 105 degrees or so with my 15000lb trailer behind, it hit about 215 I think. That's with the six-gun on level 3 at 55 mph. EGT's were at 1250 pre-turbo if I recall.
Marc
__________________
Marc
2004 Chevy 2500HD LB7 D/A LT CC/SB. Superconductive blinker fluid, ABEC-5 muffler bearings, high flow tinkle valve, strengthened fremble keys, custom spindle huckers and infinately adjustable actuator nubbins matched to polished and matched tweedle ports, dual piston return springs, and some other stuff that comes off when it goes in for warranty work.
  #6
Old Posted 11-07-2005, 01:25 PM in reply to Burt4x4's post starting "The gage for mine is about 200-205 all..."
miniwally's Avatar
Quote:
Same guage readings as mine. I hook up my Predator and do inflight checks and see 195 degrees on the predator at the same time I see the roughly 200 to 205 reading on the factory guage. I guess one of them is a bit off.
I think all engines these days a running on the high end of the 190s to the low end of 200 for normal temps. I think it has something to do with Emissions???
  #7
Old Posted 11-07-2005, 02:50 PM in reply to miniwally's post starting "Same guage readings as mine. I hook up..."
Ya I would guess emissions and maybe cuz of the higher compression thease engines are running...?
  #8
Old Posted 11-08-2005, 12:13 PM in reply to miniwally's post starting "Same guage readings as mine. I hook up..."
RJF's Red Cummins's Avatar
TRC Staff
Quote:
From what I know, thats it. THe hotter they can get them to run the better off they are with burning everything up for emmissions, or so I've been told.
__________________
  #9
Old Posted 11-08-2005, 01:36 PM in reply to RJF's Red Cummins's post starting "From what I know, thats it. THe hotter..."
Terrain Twister Terrain Twister is offline
It's all emmisions related. The compression ratios are actually going down while the turbo boost pressures are going up.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
