TowRig.com
Go Back   Diesel Forum - Cummins, Duramax, Powerstroke & Towing Forums > General Tow Rig Forums > Towing Equipment
Sponsor
Reply
Thread Tools Display Modes
  #1
Old Posted 12-14-2005, 12:15 PM
mbryson mbryson is offline
In bed storage---truck bed
I'm not sure I want to know about other beds......
I just moved from an SUV to a pickup (shortbed) and am looking for in bed storage solutions. The Delta toolboxes are slightly tempting, but I'd like to keep the box under the bed rails and would definitely like to have some security on it. Creative, clever, low cost options are WELCOME. (cuz I'm a cheap bastid and they'll match my Jeep better )
Let's see what you've got.
There's got to be more than what's in this thread http://towrig.com/forums/showthread....ck+bed+storage
These look like interesting concepts.......
http://www.duluthtrading.com/store/o...ers/56439.aspx
http://www2.northerntool.com/product-1/200008324.htm
Sponsored Links
  #2
Old Posted 12-14-2005, 12:54 PM in reply to mbryson's post "In bed storage---truck bed"
BadDog's Avatar
BadDog BadDog is offline
TRC Staff
Well, I've got several options I swap out for various uses. There is a mini-truck diamond plate tool box that I use for spare axles, ratchet straps, and tools when on long wheeling trips. It sets in the bed near the cap and is rigged so that I can run a cable through it to secure to the bed tie downs and then lock from inside the box. I've got various sizes of amo boxes that can easily be modified for locks and they seal air tight. Also easily adapted to secure. And then I've got the "coffins" which are large RubberMade bins this latching lids. These hold our bags with cloths and stuff that's not too terribly heavy, but I don't want to get wet or dirty on the road. Those just get ratchet strapped in.
__________________
2002 Dmax/Allison CC 4x4 SWB Juice/Attitude, 65 gallon tank, 30k goose/5er, 33" ATs
  #3
Old Posted 12-14-2005, 09:30 PM in reply to BadDog's post starting "Well, I've got several options I swap..."
dubbyx's Avatar
dubbyx dubbyx is offline
x2 on the rubbermaid "coffins".... I lived outta 2 of those in the back of a mazda mini-truck when I worked in TN for 3 months. Super cheap, mine had holes to put a padlock through, and they were plenty weather resistant. I drilled holes in the bottom of mine and bolted through wood blocks down to the bed so no one would jack them. They looked ghetto, but they survived Memphis and Nashville just fine.
  #4
Old Posted 01-02-2006, 10:37 AM in reply to dubbyx's post starting "x2 on the rubbermaid "coffins".... I..."
Carlos Carlos is offline
Send a message via ICQ to Carlos Send a message via AIM to Carlos Send a message via MSN to Carlos Send a message via Yahoo to Carlos
I kicked around a lot of options and finally settled on a hard bed cover. I love it. I've been able to put all my dive and boating gear there for a vacation and not have to worry about theft. I've got one of the movable load dividers too, so shopping trips are easier (just fill up the space between the divider and tailgate). The cover is very versatile and has proven to work well even with oversize loads. It consists of four hinged panels and opens at the front and back. It's easy to open as many panels as you need, or just an end.
I got mine from aztrucks.com for just under $600.
  #5
Old Posted 02-12-2006, 05:08 PM in reply to Carlos's post starting "I kicked around a lot of options and..."
rocknbronco's Avatar
rocknbronco rocknbronco is offline
Send a message via Yahoo to rocknbronco
I can tell you to save some money on those Delat boxes go to your local Tractor Supply Delta makes em and they are great.Mine has a lock and its a pain sometimes but most of the time its great and I'm looking forward to getting a 56 gallon fuel container as well,if I ever get the money for it and to fill it up,mine sits on the bed rails but I perfer that.Check out what other styles they carry.
__________________
Wifes Daily Driver 03 Toyota Tundra Limited Ext Cab 4X4 4.7 K&N Air Filter Tool Box BFG Rugged Trails
DD/Tow Rig 05 SD F250 XLT FX4 Crew Cab Long Bed TorqShift 5.4 3V Triton K&N Air Filter Valley 3 Ball Hitch TS Tool Box FS Transforce
Trail Rig 88 FS Bronco XLT C6(w/B&M 2K Stall and Stage 2 Shift Kit,1st&2nd from AOD) 1356BW 351 Winsor K&N Air Filter Valley Ball Hitch 33X12.50 Goodyear Wrangler MT/R's Solid D44 for swap in future
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
