#1
nv4500 5th gear fix article
i found this and wanted to share with all who might want or need to fix the 5th gear problem. http://dodgeram.info/tsb/1998/21-10-98a.htm
__________________
TOW RIG : 96 CHEVY 1 TON 2X4 CREW CAB LB 350/4L80-E/14FF/4.10/G80 10KLB EQUIPMENT TRAILER 6K RAMSEY WINCH ON TRAILER ![]() backup rig :79 k30 flatbed/plowrig/dump/playtoy. 350 tbi 4speed 4.10 gears and 35" tires. |
| Sponsored Links |
#2
A friends 01 dodge just lost 5th. It comes and goes. Plan is to just tighten nut then put a spot weld on.
__________________
1997 Reg cab 2500; 5" lift; 315s on M/T Classic IIs;5" straight exhaust; #100 plate; BHAF; KDP tabbed; Ultra-lite pyro and boost, and other misc goody goodies... 1971 Chevy K5 build |
#3
reason i found it was i got a salvage yard 4500 tranny. has a small hole in back cover. wanted to make sure i wasnt opening a big can of worms when i remove it to have it tiged back shut. i think i will weld the nut in a spot or 2 when its off so i dont have that problem.
__________________
| Bookmarks |
| Thread Tools | |
| Display Modes | |
