#1
Load E tire sizes
I'm needing to replace my tires on the towrig. I haven't found alot of variety of sizes for load Es.
If your running Es, please post up tire size, brand and cost estimate per tire. Also I've got a dually so they have to fit the rear with out rubbing together.
__________________
John2002 PSD CrewCab Dually 4x4, 7.3/auto with 2006 front clip. Isspro guages, DIY intake, 4 pos chip, 235/85/16 BFG ATs. |
| Sponsored Links |
#2
man EVERYONE makes E range tires... you must not be looking hard enough...
__________________
tow rig: '06 RAM 3500 DRW, 4WD, 6SPD, and NO it doesn't have a HEMI what i tow: 50ft kauffman car carrier, K5 based buggy, and whatever else my friends can bribe me to haul out of town for them... |
#3
Guess i should have mentioned that I'm not looking for a street tire. I'm looking for something in an AT or MT.
__________________
#4
Check out pro comp. the ads usually just list the c and d tires, but they do offer a few sizes in E. just call them up, and they'll tell you whats available.
#5
![]() BFG Commercial TA Traction 265/75R 16 E rated @ 3415 80Psi So far I am very please with this tire. The size listed above was the largest it came in...when I last checked anyway & if you need to you can add ice studs to thease...
__________________
'05 Sliverado 2500HD LT CrewCab Longbed Duramax/Allison 4x4 Towing my '72 K5/Blazer w/MPFI454 7/8ton
#6
Will a xxx/75/xx work on duallys? They come with 85s.
__________________
#7
It depends what the first # is. the first number is the tread width in mm. The second number is the aspect ratio (sidewall height) in percentage of the tread width. ex. a 200/75/xx would be 200 mm tread width and sidewall height would be 75% of tread width, or 150mm in this example. Dually's usually have a smallish number for tread width, and therefore need a larger percentage of that width to make a decent sidewall height.
I hope this didn't confuse you. |
#8
toyo open country AT is available in a 235.85.16 load range E
also the mastercraft AT, which is made by cooper and very affordable... then a MT is a sumitomo-cooper all in stock load range E size... hope this helps...
__________________
#9
I got Toyo Open Country AT's on my dually, 265/70-17's LR-E
I'm putting 315/75-16 Toyo MT's on my F-350 next month, LR-E
__________________
05 Dodge, CTD/6-spd, Quad Cab Dually, AFE torque tube and drop in filter, T&J performance muffler, no cat, guages. 40K in one year exactly 96 F-350, PSD/5-spd, STD Cab long bed, LUK clutch, 315/75-16's, Shackle flip, 4" straight exhaust, TS 6-pos chip, Homemade intake, guages. 180K 66 Ford Bronco, SEFI 351W, ZF-5, Atlas 5.0, D60/ARB/5.13 35 spline front, D60-14/spool/5.13 35 spline rear, 4 link, 39 Krawlers, M8274, OBA |
#10
I'm running BFG Rugged Trails and love em they ran about 150.00 a pop for my wifes truck but they were D rated I'v got E's check my sig
__________________
Wifes Daily Driver 03 Toyota Tundra Limited Ext Cab 4X4 4.7 K&N Air Filter Tool Box BFG Rugged Trails DD/Tow Rig 05 SD F250 XLT FX4 Crew Cab Long Bed TorqShift 5.4 3V Triton K&N Air Filter Valley 3 Ball Hitch TS Tool Box FS Transforce Trail Rig 88 FS Bronco XLT C6(w/B&M 2K Stall and Stage 2 Shift Kit,1st&2nd from AOD) 1356BW 351 Winsor K&N Air Filter Valley Ball Hitch 33X12.50 Goodyear Wrangler MT/R's Solid D44 for swap in future
| Bookmarks |
| Thread Tools | |
| Display Modes | |
