#1
Need Help
I have an 03 GMC 2500 hd and last night the brake lights wouldn't turn off. They stay lit like I am in the cab pressing the pedal. Any ideas on what the problem might be?
Thanks |
| Sponsored Links |
#2
there usually is a sensor connected to the brake pedal that tell the lights when to go on or when to stay off that might be the problem I have had one go bad on my Bronco and experinced the opposite problem its was cheap under twenty bucks to fix.
__________________
Wifes Daily Driver 03 Toyota Tundra Limited Ext Cab 4X4 4.7 K&N Air Filter Tool Box BFG Rugged Trails DD/Tow Rig 05 SD F250 XLT FX4 Crew Cab Long Bed TorqShift 5.4 3V Triton K&N Air Filter Valley 3 Ball Hitch TS Tool Box FS Transforce Trail Rig 88 FS Bronco XLT C6(w/B&M 2K Stall and Stage 2 Shift Kit,1st&2nd from AOD) 1356BW 351 Winsor K&N Air Filter Valley Ball Hitch 33X12.50 Goodyear Wrangler MT/R's Solid D44 for swap in future
#3
just check the wires and look for wear or exposed wires around the sensor and wiring harness check the conection and make sure they are all tight if I'm thinking right that should fix it.
__________________
#4
Quote:
Thanks Jason |
#5
Glad to have been able to help
__________________
| Bookmarks |
| Thread Tools | |
| Display Modes | |
