TowRig.com
Go Back   Diesel Forum - Cummins, Duramax, Powerstroke & Towing Forums > Ford Specific Tech Forums > Ford Powerstroke 6.0
Sponsor
Reply
Thread Tools Display Modes
  #1
Old Posted 01-11-2007, 11:44 AM
Diesel Nut's Avatar
Diesel Nut Diesel Nut is offline
Send a message via AIM to Diesel Nut
Amsoil ATF available for 5R110!
Amsoil Just released this on the new availablilty of fluid that meets the Ford Mercron SP spec -
AMSOIL Synthetic ATF is recommended for the latest manufacturer
specifications.
Automatic transmission technology has been quickly evolving over the past few years.
Six-speed transmissions are becoming more common, and automakers are demanding
higher quality, longer lasting transmission fluids to protect these transmissions.
General Motors, for example, recently introduced its DEXRON® VI specification.
Established to provide extra protection for 2006 vehicles equipped with six-speed Hydra-
Matic transmissions, DEXRON VI fluids are also recommended for transmissions built
before the 2006 model year. DEXRON VI represents a significant upgrade over previous
specifications. In order to minimize fluid degradation and ensure improved performance
in extreme conditions, DEXRON VI fluids require greater oxidative and shear stability,
foam performance and protection against pitting. According to GM, DEXRON VI
fluids provide more than twice the durability and stability in friction tests than fluids
meeting previous specifications.
Ford Motor Company, on the other hand, recently announced the retirement of its MERCON
® automatic transmission fluid specification, opting to promote its more stringent
MERCON® V specification that requires improved anti-oxidation, antiwear and antishudder
properties. Ford also introduced its MERCON® SP specification in 2004.
Designed for high torque six-speed transmissions, MERCON SP fluids have lower viscosity
requirements and more stringent cold-temperature Brookfield viscosity requirements.
AMSOIL Synthetic Automatic Transmission Fluid (ATF) exceeds the performance
requirements for domestic and foreign automatic transmission fluid applications, and is
now recommended for cars and trucks calling for DEXRON VI, MERCON V & SP,
NAG 1 & 2 and Nissan Matic J & K transmission fluids. AMSOIL ATF provides automatic
transmissions, power steering units and hydraulic equipment with excellent
lubricating protection and better performance over a wider temperature range than conventional
automatic transmission fluids.
• Resists thermal and oxidative degradation
• Ensures cool transmission operation
• Provides outstanding low temperature protection
• Improves fuel economy
• Provides smooth shifting
• Maximizes transmission performance and service life
• Reduces maintenance costs
• Offers extended drain intervals
Transmission Fluid is recommended for use up to 60,000 miles in severe service
and up to 100,000 miles in normal service, or according to the vehicle manufacturer
recommended intervals, whichever is longer. Drain intervals may be extended
further with oil analysis.
AMSOIL Synthetic ATF is recommended for transmission, hydraulic and other
applications requiring any of the following specifications:
• GM DEXRON II, III & VI
• Ford MERCON, MERCON V & SP
• Chrysler ATF+ through ATF+4®
• Honda Z-1 (Not for use in CVT transmissions)
• Toyota Type T and T-IV
• Mitsubishi/Hyundai Diamond SP II & III
• Allison C-3, C-4, Caterpillar TO-2
• Voith G607, G1363
• ZF TE-ML 14A, B & C
• MB 236.1, 236.2, 236.6, 236.7, 236.9
• BMW 7045E, JWS 3309, NAG 1 & 2
• LT 71141 (ESSO), Nissan Matic D, J & K
• Vickers I-286S & M-2950S
Excellent for power steering units that use ATF.
Not for use in CVT transmissions.
Anyone needing Amsoil or filters for your Ford, PM me for Forum only special pricing!
__________________
Diesel Nut Motorsports.com
Everything for performance at great prices!
1-800-450-7036
Our Amsoil online Store
Save some money - Become an Amsoil Preferred Customer here
Make some money - Become an Amsoil Dealer here
Sponsored Links
  #2
Old Posted 02-06-2007, 11:05 PM in reply to Diesel Nut's post "Amsoil ATF available for 5R110!"
Patrick@DPP's Avatar
Patrick@DPP Patrick@DPP is offline
Send a message via Skype™ to Patrick@DPP
Diesel Nut, that is very interesting. I run the full synthetics in the motor...got to love the 20k mile oil changes...does Ford say this trans fluid is good to go? I see what you said above, but if you come in with a burnt trans, and there happens to be Amzoil in it will they warrant the rebuild on the 5R110? Most likely your everyday tech wouldn't notice, but just say it was discovered.
Thank you,
Patrick
  #3
Old Posted 02-07-2007, 01:33 PM in reply to Patrick@DPP's post starting "Diesel Nut, that is very interesting. I..."
Diesel Nut's Avatar
I have it on my hard drive somewhere, but there is a law stating that if the company requires that you use their brand of servicing parts (oil is a part) to maintain warranty then they are required to supply it to you free of charge. This is why all BMW cars come with free servicing for the first, what, 50k miles I think. They want their own brand in it. Fed Law requires them supply it free of charge.
As for a burnt transmission, first, they are going to have to prove that the fluid was the reason it failed. That will be tough to do. IF they can prove without a doubt the fluid was the cause of the failure, Amsoil's warranty will cover it. Here is that warranty.
Here is a question/answer thing Amsoil distributes to its dealers when there have been a buch of people asking about something. Hope this helps.
AMSOIL Automotive Applications - ATF
Q. How can AMSOIL Universal Automatic Transmission Fluid (ATF) with a viscosity of 6.8 cSt be recommended for DEXRON VI and MERCON SP with respective maximum viscosities of 6.5 and 6.0 and also be recommended for ATF+4 with a minimum viscosity of 7.3?
A. AMSOIL positioned the viscosity of the AMSOIL Universal Automatic Transmission Fluid in the middle of most of the specifications from many manufacturers. These specifications include:
* GM DEXRON II, III & VI
* Ford MERCON, MERCON V & MERCON SP
* Chrysler ATF+ thru ATF+4
* Honda Z-1 (not CVT)
* Toyota Type T & TIV
* Mitsubishi/Hyundai Diamond SP II & III
* Allison C-3, C-4
* Caterpillar TO-2
* Voith G 607 & G1363
* ZF TE-ML 14A, B & C
* MB 236.1, 236.2, 236.6, 236.7, 236.9
* BMW 7045E
* JWS 3309
* LT 71141 (ESSO)
* NAG 1 & 2
* Nissan Matic D, J & K
* Vickers I 286S & M2950S
For years original equipment manufacturers (OEMs) were primarily concerned with efficiencies at cold temperatures. Cold temperature performance of fluidity is measured by the Brookfield viscosity in Centipoises (cP) at -40°C (See chart 1). Chart 1 provides the maximum viscosity allowed at -40°C. This insures proper flow of lubrication to internal components at cold temperature for good lubrication.
(Chart 1)
ATF Brookfield Viscosity (cP) Comparisons
MERCON <20,000
MERCON V <13,000
Mercon SP <9,500
DEXRON III <20,000
DEXRON VI <15,000
Chrysler ATF+4 <10,000
AMSOIL ATF 9,326
As of recent, OEMs have begun to regulate the maximum viscosity of the oil. It is generally accepted that thinner oils improve operating efficiency. By limiting the upper viscosity, such as with DEXRON VI and MERCON SP, OEMs are trying to capture the additional efficiency, no matter how small it may be. The two newest specifications, DEXRON VI and MERCON SP, have a starting viscosity maximum of 6.0 cSt and 6.5 cSt respectively. Although AMSOIL ATF at 6.8 cSt has a slightly higher viscosity than MERCON SP and DEXRON VI and a slightly lower viscosity than ATF+4 (7.3 cSt), it does not negatively affect performance in any of those applications. With respect to MERCON SP and DEXRON VI, AMSOIL ATF fulfills the cold temperature requirements so the marginally higher viscosity of 0.3 to 0.8 cSt will only provide better protection. With respect to DEXRON III, MERCON V and ATF+4, our experience has shown that conventional oils may shear down to below 5 cSt during use. Additionally, DEXRON VI is recommended as a replacement for DEXRON III so the lighter viscosity for AMSOIL ATF is immaterial.
AMSOIL recommendations are based on sound technical principles. Because of its superior base oil technology, AMSOIL ATF fulfills the important cold temperature requirement and its inherently high viscosity index contributes to a higher base oil viscosity and ultimate shear stability. AMSOIL ATF is compatible with all the seal materials and its oxidation and frictional properties are extremely stable. AMSOIL ATF is perfectly positioned to work in all the listed applications.
__________________
1-800-450-7036
  #4
Old Posted 02-07-2007, 01:41 PM in reply to Diesel Nut's post starting "I have it on my hard drive somewhere,..."
Good information, thank you!
  #5
Old Posted 02-07-2007, 06:11 PM in reply to Patrick@DPP's post starting "Good information, thank you!"
nastee1 nastee1 is offline
Whats the sale on the bullydogs Diesel Nut? My dad is looking for one 05 Dodge 2500
  #6
Old Posted 02-08-2007, 10:17 AM in reply to nastee1's post starting "Whats the sale on the bullydogs Diesel..."
Diesel Nut's Avatar
Nastee1 - PM on the way!
Patrick@DPP - No problem. Feel free to keep the questions coming if you have them. It makes for a great way to get the information out so all can learn.
__________________
1-800-450-7036
  #7
Old Posted 02-20-2007, 10:40 PM in reply to Diesel Nut's post starting "Nastee1 - PM on the way! Patrick@DPP..."
DieselNut, I took my truck in last week for state inspection sticker. When I picked it up they told me since the oil change sticker said it was changed 5k miles ago they gave me a free oil change. What a bunch of nice guys. They thought they were HOOKING me up since I always bring them parts. When I told him he owed me for another oil change because I still had 15k miles to go, he almost fell over. What a bunch of nice guys. lol
__________________
-Patrick-
2005 F-350 CC, LB, SRW
Custom SCT Elite Diesel, Innovative Diesel 439hp
MBRP "Cool Duals" 6" tips
AiRaid Intake w/ pre-filter
Quadzilla Commander Digital Display
ReadyLift Leveling kit
Pro-Comp Xtreme AT's 33x13.5x18
N-Fab nerf bars
4 Pro-Comp 8" lights out front
Carriage Works Grill Inserts
Mods sitting on shelf: lol...installed someday!
Snow Performance Stage III water/meth injection.
  #8
Old Posted 02-20-2007, 11:28 PM in reply to Patrick@DPP's post starting "DieselNut, I took my truck in last week..."
Diesel Nut's Avatar
Sweet!
i would have loved to see the looks on their faces!
__________________
1-800-450-7036
  #9
Old Posted 09-12-2007, 01:31 PM in reply to Diesel Nut's post starting "Sweet!waytogo i would have loved to..."
SubYuman SubYuman is offline
Price versus SP
Since it's $4+ a quart for SP, how dos the price compare with AMsoil?
  #10
Old Posted 09-15-2007, 10:34 PM in reply to SubYuman's post "Price versus SP"
Diesel Nut's Avatar
PM on the way.
__________________
1-800-450-7036
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
