#1
question
hey guys i just bought my dads 97 12v with 468k on milage an was wondering we have put the 618 planetary in the tranny and rebuilt the overdrive unit andam wondering if putting a number 12 or 11 fuel plate and 3k gsk would be a good idea or bad, because of the milage on the truck. so any opinions would help me thanks.
-Jon |
| Sponsored Links |
#2
The engine will be fine with it, but the trans & torque converter may not. Your trans should already be an A618(47RE). A #10 plate works best with a GSK, other than a #0 or 100 that is.
__________________
12 valve 6BT, 6CT and DT466 "enthusiast" low buck diesel fuel rate site of mine: http://www.freewebs.com/nevrenufhp/index.htm project rig: 99 Super Duty, AT545 Allison, DT466 |
#3
I guess one of the questions should be, "what shape is the tranny in?" I know you said you put in a new planetary gear (I agree with nevrenuf, the 618 should be stock for that year) and rebuilt the OD, but how about the Tq converter? I put a #5 plate, 3k GSK and 215hp injectors on my 12v with a stock (although it had been rebuilt) transmission with no problems for about 90,000 miles..... that included towing a 21ft trailer from time to time.
__________________
'09 Ram 3500 MegaCab 4x4 Dually '95 Ram 3500 2wd tweaked a bit runnin' @ 236/555 with a BHAF, 215's and a #5 plate |
#4
tranny
i know from the paper work from the truck, that amco rebuilt it at 270,000, but it nowhas 470,000 and the fluid looks good and red, had the pan off no burned clutches or any debri, but your ight i dont know the real story on the converter i know it locks up what seems good for stock, but i'd be afraid to add power and have it go out. i'm lookin at a TCI converter and building the tranny stronger.
#5
Well, that's 200k mi. on the rebuild and if you don't know the history of that 200k ..... as far as prevent. maint. & upkeep..... you could be taking that chance. But..... just because you put those mods into the engine doesn't mean you have to drive like its got mods; thereby, preserving the tranny until you can do something with it. In other words, I don't think the $$ spent on the plate and GSK will be $$ wasted. Does the truck have gauges? If not, you'll want to do that first, or in conjunction with the engine mods.
__________________
#6
Just adding a VB would help the trans last longer.
__________________
TV: 01 Dodge 2500 quadcab 4X4: Cummins ,auto(Goerend TC/VB, BW trans, deep pan),TC lockup switch,gauges,edge comp,rv injec,holley fuel pump,permacool fuel/water filter,big banjo fuel bolts,180 stat,high flow exhaust w/BHAF.
#7
Just hop it up and see what happens....
If you take off for the first time with new power, lay into it hard, and it the trans slips like crazy..... the trans isn't going to just fall apart instantly with one little slipy slipy. If it won't slip, then you are good to go, if it does and you have the will power, put the stock plate back in the truck or run it until it dies and put in a Suncoast trans or something of the like.
__________________
'06 3500 Mega W/mods '01 2500 QC W/mods |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
