#1
6.2L Cylinder not firing..whats the cause?
So what will cause a diesel cylinder not to fire.
Glow plug(please explain) i thought they only ran when you started the truck up? Plugged injector bad valve??? low compression? how can i check these easily? Glow plugs. I can pull one out and look at it? Injector? valve-pull the head? compression test.... thanks for your help. I will try and play with it tonight and see what i come up with! Stew |
| Sponsored Links |
#2
I am not sure if the 6.2 had injectors or used a throttle body type injection (I really have no idea). but if it does then that or a bad valve could be the culprit. try a compression test and a leak-down test and see what you come up with.
good luck! EDIT: I just re-read your post, the glow plugs shouldnt cause this, but if you have never changed them then it wouldnt hurt to do it anyway.
__________________
-Brent Personal Tow Rig/Wifes DD- '04 Chevy Tahoe 5.3 3.73s 4x4 Last edited by Brisk; 07-27-2005 at 02:16 PM. Reason: add info |
#3
I would do a compression test and maybe a leakdown test, and pull that injector and have it tested at a local diesel injection shop.
__________________
James email:jac6695@hardcore4x4.com 97 K2500HD GMC Ext Cab, L65 6.5TD, 4L80E, HeathDiesel ECM reflash, Turbo Master set at 15 PSI 3.5" Exhaust, No Muffler, Intercooler, 3.73, 4" Tuff Country lift, 315/70-17 on H2 Wheels, 151,000 miles 86 S10 Blazer (on K5 frame), LT1, 4L60E, Doubler, D60/14B, 42x14/17 IROKs on H2 wheels & much more |
#4
Quote:
__________________
-Brent Personal Tow Rig/Wifes DD- '04 Chevy Tahoe 5.3 3.73s 4x4 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
