2000 7.3 cold start problem
Discussion in 'Ford Powerstroke 7.3' started by 99ncxj, Jan 8, 2009.
  1. 99ncxj
    99ncxj Member
    Belmont, NC
    got a quick question. on my 99 super duty, its getting hard to start in the morning when its very cold. does this sound like glow plugs? I've heard that it can also be the controller for the plugs. any ideas?
    oh, its got 340,000 some odd miles on it too.
  2. Woods
    Woods Well-Known Member
    Its probably the glow plugs, the less working the harder it is to start.
  3. strai8up
    strai8up Well-Known Member
    Middle Georgia
    I 've been trying to get the wiring schematic for that . I have the same problem and just want to ck everything out before I pull valve covers at 60.00 each for gasket.----------- this is on nephews 99' 7.3
  4. LOUDandPROUD
    Kodiak, Ak
    Glow plugs for sure, everyone else in my family runs powerstrokes. It seems glow plugs is just one of those things you have to change. I havent heard of too many controllers failing. The plugs wear out on a regular basis though.
  5. tonkatoy01
    tonkatoy01 Member
    N. Illinois
    it might be one of the relays. i had one of my friends come over and look at my truck. he took a volt meter and tested both relays. i believe that the 2 are the glow plug relay and the air intake heater relay, with the heater relay towards the grill. thats what my buddy said i have low amps or voltage. my glow plug relay was still good. he did say it might be the glow plugs.
    ive got the haynes repair manual for Ford Superduty 3/4 and 1 ton pickups, 99' - 02' book number is 36060
  6. strai8up
    Middle Georgia
    sorry for late response . It was the controller . All plugs checked ok . very suprised at 240,000 miles
  7. diesel95ford
    diesel95ford Member
    Omaha, NE
    the glow plug relay on the 7.3 powerstroke's are common for going out. they get to hot trying to heat the glow plugs in the winter time
  8. HozzyNutz
    HozzyNutz New Member
    Massachusetts
    I just had to do my controller. Ordered an el-cheapo from ebay, and ended up having to get a good one. Cheapo wouldnt complete a circuit. Grrr :mad:
