Speedometer issues
Discussion in 'Ford Diesel 6.9 | 7.3' started by Gone Huntin', Mar 28, 2006.
  1. Gone Huntin'
    Gone Huntin' Member
    Horn Lake,MS
    Does anyone have any experience with the speedometer running too fast when cold? It works normally when the truck/ambient temps warm up a bit. It is mechanical in my '91 F250 4X4.
  2. vincent jarvey
    vincent jarvey Member
    :confused: Thats kinda wierd maybe if you replaced it?
  3. john12121
    john12121 Member
    US
    First of all confirm if the speedometer gearing is correct by checking the odometer reading. Gearing is incorrect if reading are out by few percent. IF not then the problem is with the magnetic portion of the speedometer and will have to send it off for a rebuild. Sometime tire size does affect the speedometer speed and if you have abnormally small ones that could be the problem..
