I have a 98 12v with #10 plate slide foreward,banks turbine housing,4 inch exhaust,cold air kit.Am adding 80hp injectors, 3000gsk,ats exhaust manifold & a fluidamper.How much hp is gettin to the ground?Will my turbo hold up?And will my pump handle this?
sounds good! Hey, Thanks For The Reply.the Truck Is A 5 Speed, So Will It Be More Than 325hp? How About My Stock Turbo?will It Last?
With a 5spd it comes with a 913 pump, you will potentially be higher hp, up near the 360 mark with what your talking.
The turbo will be at the upper limits, but it'll live. Depends on where the "80hp injectors" are from, but I'd put it at about 360-370hp at the wheels minimal. The bad part; your clutch WILL slip.
Is the boost on a stock turbo adjustable? if i had a #0 plate would i need a bigger turbo for sure, i don't want a smoke trail behind me all the time.
