they are vision aluminum never been mounted 3 in unopened box 1 in opened box asking $650.00 located in moorpark (ventura county)california i decided to go a different way
Could you please give me the specs on these wheels? The more the better. Most important the max PSI and max LOAD. Thank you!
i sold the rims a while ago,i believe the weight rating was 3190 lbs tires could of been inflated to around 100 psi ,they were a direct bolt on (no adapters) hope that helps you
