02 F350 SD 4X4 Dually 7.3 Ball joint Replacement
Discussion in 'Ford Powerstroke 7.3' started by Hauln Da Load, Apr 8, 2008.
  1. Hauln Da Load
    Hauln Da Load Member
    How hard is it to change the ball joints, what is involved, does the axles have to come out? Thanks for any help.
  2. Hauln Da Load
    You mean to tell me that none of you Ford experts out there have no response.
  3. diesel95ford
    diesel95ford Member
    Omaha, NE
    on a 02' I'm not sure but i do know that on a 95' f350 you have to tear it down to the knuckle, the axles do have to come out to be able to get the knuckle off
  4. Hauln Da Load
    Thanks diesel95ford, I got up first thing this morning and took a 35 min walk to the nearest Auto Zone to take a look at a Haynes repair manuel and found out that I just needed to knock out the shaft main seal from the steering knuckle and then the shaft would just slide out, therefore allowing me to get access to the ball joint nuts. Now my next problem is getting the ball joints pressed out of the steering knuckle and the new ones in.
  5. diesel95ford
    diesel95ford Member
    Omaha, NE
    there are many ways to do that. if you dont have a press you can get the old ones out with a socket and a hammer and use a piece of pipe and hammer to get them back in. you can also bye a ball joint and u joint service tool that makes it simple to change out ball joints
  6. Hauln Da Load
    Thank you, I will try the socket and hammer suggestion.
