2005 Ford F-350, DRW, 6.0L, Supercab, Lariat, FX4, 8’ bed, 55,300 Miles, Compound-Turbos, Original Owner, Clean Title in hand Truck has the following add-ons: B&W lighted “cab protector” JadSolutions “FireStars” under door lights AMP Research “PowerSteps” Isspro above mirror gauges –pyro,boost, and trans temp. *Stage 4 “Max Power” 240cc Injectors *Fire Ring Kit *Coolant Circulation Line Kit *“High Power” Compound Turbos *Low Pressure Oil Pump Gears *Stage 2 Fuel System *Stage 1 Camshaft *Competition Pistons/0.20 Over Bore *Competition Piston Ring Set *Coated Main Bearings *Coated Rod Bearings *Forged Connection Rod set *Billet Flex-plate SFI *FS2500 Bypass Oil Filter Kit *Stage 1 Valvetrain Upgrade *H-11 Head stud Kit *H-11 Main stud Kit *Remote Oil Cooler Kit AFE Stage 2 XP Air Intake System Spearco Intercooler 4” MBRP Dual Exhaust System- Stainless -Turbo Back Suncoast Transmission with Competition Upgrade, Triple Disc Torque Converter , Mag-Hytec Trans Pan, and Billet Shafts *Bought from “Elite Diesel Engineering” *All engine parts installed at 51,444 miles by “Elite Diesel Engineering” *Transmission installed at 51,320 miles *Other parts included but not installed are: B&W Turnover Ball Gooseneck Hitch, Firestone Ride-rite Airbag Kit, Black Cloud Diesel Stack kit with 6” Mitre Stack *Will also include 24 quarts of Mercon SP Transmission Fluid, 3-Oil Filters, 1-Transmission filter, 3-Fuel Filters, 2-FS2500 oil filters, and a New Black Grill Listed on ebay also. Item # 180729878713 Pics located in signature.
