In good shape, new tires, brakes, wiring, paint. Located in Crestview Fl, 32539 24' plank deck 33+ overall (8+' goose) VERY heavily built 10" channel frame, goose is 10" channel with 6" channel welded inside it!! Not sure of the weight rating, 6 lug axles. If wanting to pull cars, D rings will need to be added because there aren't any. Pulled it from maine to florida with no probs, tows great. Damage: Light board in the rear is bent under a bit like someone backed into something but it's an easy fix and I will bend it back if I get the time. Asking $3200 firm or trade for good running jeep cj,yj,tj,fj40,early bronco, any ponycar from 65-72, 86+ V8 Mustang. Must run good enough for a DD (NO PROJECTS), needing bodywork paint ok. May also swap for a good motorcycle. I'm selling because I don't need it anymore, it's a little bigger than I need, and I need a DD. The box on the front was plywood that I built using the stake pockets to protect our funiture on the trim and has since been removed.
