40' livestock trailer
Discussion in 'GM Duramax 6.6 (LBZ | LLY)' started by Power Stroker, Jan 6, 2006.
  1. Power Stroker
    Power Stroker Member
    Eaton
    What GM truck will tow a 25,000lb trailer. 5th wheel of course.:doah:
  2. Brisk
    Brisk Well-Known Member
    Castle Rock, CO
    any of them...however some will do it better and more safely. I wouldnt consider anything less than a 3500 DRW w/ the D-Max With that much weight a duelly is a must for safety and stability. If you are just going to move it around a farm any 4wd truck with a Low-range will do it fine...but is taking to the open road you will want a diesel and I would recomend the dually b/c of the pin weight.waytogo
