6.5L / any diesel ... running egt
Discussion in 'GM Diesel 6.5' started by hayaboosta, Dec 16, 2005.
  1. hayaboosta
    hayaboosta Active Member
    findlay Oh
    i just got done installing my EGT in my (pretty much) stock 6.5L .. and was wondering what a good running temp is .. i have a kennedy diesel cross pipe, custom cold air intake (if it effects egt?), and straight pipe 2 3/4" exhaust, and im running stock boost level ... i took it around the country mile and when i would get past 2K rpm it was getting close to 1100º but then at 55 in 5th it was around 5-600º and then at idle it was around 400º .. does this sound right?
    hopefully tomorrow i will get my boost guage so i can actually find out how much boost im running .. set the controller low so i wouldnt blow something up ...... 8lbs sucks!
  2. joez
    joez Well-Known Member
    New Lenox, Illinois
    EGT's sound high compared to mine. I idle arround ~300, if i let it sit for long periods i drop to nearly 200. Motor is bassically stock except for the 4" exhaust, 3" downpipe and the intake. I have yet to stand on the throttle long enough to get even much past 950*, and the only way for me to hit that is when merging uphill onto the interstate, running about 2500 RPM, and boost at all of 6 pounds thanks to the ECM. It will get to 900 fast, but after that the temps slow down alot. Cruising down the interstate at 70 mph gives me 550-600*.
  3. hayaboosta
    findlay Oh
    yeah i oopsed .. prior numbers arent completely correct according to today's drive .. from 55-75 in 5th gear (1500-2000rpm) rises to 900º (may go higher but i hate reving my truck out) then at idle it is around 300º(after about 20seconds) and regular driving is around 4-500º
    my probe is right at the top of the cross pipe on the driver side (right after manifold)
  4. jac6695
    jac6695 Well-Known Member
    Christiansburg, VA
    My probe is post turbo (just above the connection to the downpipe in the turbo housing), and I run 500-600 cruising empty, and 700-800 cruising loaded, and will go as high as my left foot will allow up hills. I try to keep it no higher then 1000, though.
