7.3 bogging down under steady throttle
Discussion in 'Ford Powerstroke 7.3' started by Shifty, Jan 13, 2008.
  1. Shifty
    Shifty Active Member
    Carl Junction, Mo
    Got a problem with the 96 PSD i just got, i swapped tanks on the way home to the rear tank and it wasnt reading right after i topped it off. SO decided to swap back to the front tank, then after that it starts bogging down (sounding kinda like an exhaust brake) when i was under steady throttle under 70mph. when you give it some more pedal and the boost comes up it goes away and seems to run fine..
    I stopped for a bathroom break later down the road and it sat for about 5-10 mins and ran fine after that when i started it back up.
    Could it be dirty fuel in the rear tank ? i dont know how long it was in there but i added some additive to it before i put like 1 gallon in and it was full.
    Tried swapping to the rear tank a few more times with the same results.
    mods are:
    Edge Evolution set on L2-race
    5" exhaust
    cold air intake
  2. 97powerstroker
    97powerstroker Active Member
    north port-florida
    did you run the tank out of fuel,i ran my tank until it started boggin down,then i switched tanks and it kept boggin for around 20 seconds,maybe you were just about to run out when you switched,maybe?
  3. Shifty
    Carl Junction, Mo
    nope wasnt running out of fuel.. was a full tank and after i switched back to the front tank it still was doing it for the next 50 miles untill i stopped and shut the truck off.
    also did it this morning when i took the kid to school, went to the insurance agent and came back out and started it up and it drove fine after that
