i know its not a tow rig but its something to tow lol 1985 blazer used to be a diesel, the motor, tranny, t-case, and axles are from an 87 chevy. the motor is a fuel injected 350 running a carb. heres the good stuff and the bad stuff. 350 MOTOR 500-1000 miles on freshly professionally built motor edelbrock timing gears edelbrock performer intake edelbrock 600 cfm (manual choke) ported and polished heads LZ1 springs one piece stainless steele valves positive energy seals J2 cam motor is all balanced 4 core radiator flex fan electric pusher fan new water pump new starter starter heat shield new alternator new diesel motor mounts fuel regulator valve and guage new fuel pump TH400 tranny new filter new pan gasket tranny cooler in 4 core radiator stage 2 shift kit (not installed, comes with) NP208 transfer case with skid plate AXLES 10 bolt front, 3.73 12 bolt rear , 3.73 new shocks new steering stabilizer powerboost brakes professionaly built rear driveline new U-joints front/rear LIFT/TIRES 35x12.50x15 wild country's (50-60%) fullsize spare 3 inch lift EXHAUST headman headers 3 inch dual exhaust dual afterburner mufflers STEREO pioneer cd player two 6x9 pioneers two 6" pioneers kenwood 600 amp kenwood 12" sub truck runs very nice NO RUST, but must sell to buy house. has tach on dash, bedliner interior, newer dash pad, grant GT steering wheel, aluminum grille, top has luggage rack (stock) and sliding tinted windows. you can view the building of this truck at http://sore4x4.com/forum/viewtopic.php?t=178 now for the bad stuff on this truck it needs a paint job, the doors and hood are from the 87 so the colors dont match. the windshield is cracked. the back window, the motor was replaced and it works from the switch but the gearbox in the tailgate is stuck, so i unbolted the glass and slid it down in the tailgate. theres a couple dents in the top of the cab from where someone sat on it. and one small dent behind the passenger door. have original electric doors if you want those (switches worked). if you have any questions or want pics just ask and ill do my best to answer them. possible delivery for fuel money possible trade for a 4x4 yota THANK YOU
