'95 F-350 w/ 7.3 DIT, cranks, but no start.
Discussion in 'Ford Powerstroke 7.3' started by fairlane_68, Jan 3, 2008.
  1. fairlane_68
    fairlane_68 Member
    Lawton/Fort Sill, OK
    There's no PCM communication/response with an NGS tester, PCM is getting power from good fuses and good diode, wiring from fuse block to PCM connector is good. PCM is good. When key is turned on, MIL flickers for a split second, and that's it. Wait light operates normal. What am I missing?
    I've changed the PCM relay, put a reman PCM in, unplugged the EBP Sensor and the fuel heater on the fuel filter housing, I have power to and from the PCM relays (battery voltage), and at the PCM connector.
    Has anyone ever heard of te MLP/TR Sensor causing a similar problem? The truck has an E4OD.
  2. Bourdon1350
    Bourdon1350 Well-Known Member
    Weatherford, Tx
    check your cam sensor.
  3. fairlane_68
    fairlane_68 Member
    No communication with the PCM. CMP's don't cause that problem. I'm tearing the truck apart tomorrow...I'm thinking it's a wiring problem.
