7800$ St George UT 1997 dodge cummins 12v 174k miles 5spd 4x4 lifted front end leaf conversion with new 4 inch springs and a ford high pinion kingpin axle, custom flatbed my buddy built with gooseneck hitch in it.. I have invested alot into the truck recently i have replaced-- windshield new headlights new airbags shocks front & rear new rotors calipers pads power steering box & pitman arm drag link with chevy 1 ton rod ends AFE cold air intake rear drive line, ujoints and carrier, transfercase has been gone through and replaced worn parts including a new tail housing.. Pulled timing cover and fixed KDP and while doing that replaced crank seal and re glued cover, replaced belt and tensioner, every fluid is new..has limited slip in rear 3.54 gears 315/70/16 tires .. recently been aligned. fuel plate is slid forward and cut to a 100 with AFC adjusted.. Drives strait no pulls or dodge death wobbles...drivers fender is rough and i think one wheel could be slighlty bent or just need balancing Gets about 17-19mpg empty on freeway Pulled a gooseneck with a old ford on it and got about 12mpg at about 75mph (Clutch is slips when worked hard can throw a OEM clutch in for 8000$ cash) if interested bradtoyotas@yahoo.com 435-619-6852 St George Ut
