99 powerstroke stalls
Discussion in 'Ford Powerstroke 7.3' started by times, Jun 8, 2006.
  1. times
    times New Member
    SD
    Have a 1999 3/4 ton 7.3 powerstroke, replaced fuel pump, fuel filter, drained fuel filter -water sperator, stalls after running it for 10-20 minutes, if you let it sit for a while it will restart but stalls again. Any ideas, also has 200,000 miles. Thanks
  2. BurnedBronco
    i need more info,what codes and what data is it showing when it dies?
  3. times
    times New Member
    SD
    reply
    the parts store where i borrow code reader is a demo, they had to send it back to the factory to have it updated. Be next week before they get it back. Could it be cam shaft sensor? My friends code reader showed normal but its cheap one so i don't trust it. The parts store is a pricy unit. Thanks
  4. BurnedBronco
    could be cam sensor or IPR problem to start with.
    need to monitor RPM while cranking with it dead, and IPR percentage and ICP pressure while cranking, and also B+
  5. Diesel Nut
    hows the oil look? Did you do an oil change when you serviced the fuel system? I've heard of them stalling when they get hot if you have the wrong oil in them as your injection pump operates off oil pressre.
  6. BurnedBronco
    on a powerstroke the oil even if it gets contaminated and nasty it will only cause it to run bad, be low on power and have a bad idle.
    what happens is it aireates, and this causes the problem, but the injectors only need 500psi to run, and the pumps capible of 2400, so it will usually always start.
  7. badboydiesel350
    badboydiesel350 Active Member
    North East, Ohio
    cam sensor
    sounds like the cam positioning sensor, good luck getting to it you'll need a pry bar and a set of metric wrenches
  8. davidc32707
    davidc32707 Member
    florida
    hey the same thing happen to me it was the cam sensor, my truck keep on stalling out an then it stalled out an wouldnt turn back on for like 5 mins then as soon as i started it up it the engine would just cut off so i took it to ford an they looked at my truck an told me it was the cam sensor i paid like 500 dollars to fix the problem its alot of money to pay the dealer but at least if it goes back out the dealer will fix it for free.
  9. Bourdon1350
    Bourdon1350 Well-Known Member
    Weatherford, Tx
    yeh its the cam sensor. expensive part. and its really not that hard to change.
  10. 1999GMC
    1999GMC Well-Known Member
    Carmichael, CA
    Check on ebay for cam sensor. Got one for a buddy of mine for like $65. Brand new in Ford packaging. I think his ebay name was crabmaster. They are over $200 from dealer.
  11. 1999GMC
    Carmichael, CA
  12. rocknbronco
    rocknbronco Well-Known Member
    Flat Top Mtn,Tn
    I second that
  13. stroker99
    stroker99 Member
    utah
    if it is your cam sensor sounds like it thought try napa or hendersons they'll have it about 70 bucks . tkae about one hour tops to change out not really hard to change right on the front of the motor down by the harmonic balancer even has a timming poit on it. If I remember right it a 10mm socket and a long screw drive to pry it out
  14. clarkjw24
    clarkjw24 Well-Known Member
    McBee, SC
    A PSD will not crank with low oil also. It will also cut out or stall while driving if you get on it hard and the oil level isn't correct or the right velocity (old or cold).
    Ask me how I know.:rolleyes:
  15. SNOWMAN
    SNOWMAN Member
    GREAT NORTHEAST
    ford wants 175
    Intl same part 85
    1825899-c93
  16. redpsd
    redpsd Member
    My early 99 would do that. I threw 2 CPS' at it thinking it was that. Turned out the my PCM was fried. Got that replaced and life was golden again.
  17. musicmasterstravis
    Southern Michigan
    mine was $200, thats not that bad
  18. Patrick@DPP
    Patrick@DPP Member
    Cranberry Twp, Pa
    For $55 I would get two, but I dont trust Ebay too much. If he has a good reputation I may take the chance, for that price.
  19. 427makoshark
    427makoshark New Member
    I have bought from him several times with no complaints.Same exact part as I would have paid more than double for at ford.
