AFE Stage II, how is the noise level?
Discussion in 'Dodge 3rd Gen Cummins 5.9 (24v)' started by CK5, Feb 23, 2006.
  1. CK5
    Steve,
    Have you considered a BHAF?
  3. CK5
    Yes, and from what I understand the AFE flows a little more air so might as well get the best. Just wondering about the noise level.
  4. RJF's Red Cummins
    I've heard that the AFE is a louder setup, but it might be different with a 3rd gen. I didn't think the airbox noise was much of an issue with 3rd gens since it's further forward than 2nd gens, but I don't know.
  5. Nitelord
    Nitelord Well-Known Member
    SE Pennsylvania
    I have a Stage II Magnum Force, I don't know what the difference is. (magnum force or proguard) It was on the truck when I purchased it. You can definitely hear it sucking air, but if it's louder than stock, I don't have the answer. Sorry
  6. willyswanter
    Bakersfield, CA
    Yes it is louder. If you leave the silencer ring in the turbo it's not too bad but with it out it's a jet engine... I really like it though, when the truck is idling you can hear the turbo and it sounds pretty nice. When running down the highway you can hear the turbo it's not like it keeps you from having a conversation though and I love hearing that thing spoolup when towing up a grade.
    Mine is the pro-guard stage II with torque tube. The torque tube is supposedly what makes it loud. If you get just the filter it won't be near as bad but you don't get the gains either.
  7. 451Mopar
    451Mopar Active Member
    Aurora, Colorado
    It's loud to where you can hear the turbo. Not too bad till you go over 10 psi, then it sounds like a jet powering up ;)
    On the other hand, it's quieter than my 5" exhaust.
  8. CK5
    What year rig do you have 451?
  9. 451Mopar
    Aurora, Colorado
    I have a 2005 Ram 3500 4x4, QQ/LB (single rear wheels), with AFE Stage II with PG7, Banks technicooler/highram system (includes the larger tubes and cac hoses), Edge Hot juice with Attitude, and Magnaflow stainless 5" single exhaust. The rest of the drivetrain is fairly stock for now, but have PML diff cover, ATS deep tranny pan, tripple A-piller gauge pod with ATS gauges (Boost, EGT, Trans temp.)
    I believe the AFE Stage II that I have is the same that is used on the 2006 model. I have a friend with a 2006 MegaCab with the AFE and they look the same. He is also running the Edge Juice/attitude, but it is different than the 2005 version. The 2006 has a different wiring harness, and the new Juice/Attitude for the 2006 has some extra features my 2005 dosen't have like engine/turbo shut down timmer and trans temp monitor.
    Anyhow, I think my converter is about shot so I am looking to replace it and upgrade the trans at the same time. I'd like to keep the trans cost under $3,000 if possable.
  10. CK5
    Cool, we might have to hook up some weekend, I would love to check that out, Im in Highlands Ranch.
  11. 451Mopar
    Aurora, Colorado
    Well, I'll be at the Bandimere Speedway Awards Dinner on Friday.
    Anyone else going to be there?
  12. Hossbaby50
    Hossbaby50 Well-Known Member
    Rob (therobzilla) has the Scotty II on his 99. He cut the 4" hole in the firewall for more flow and it is definilty louder when the turbo spools up. It isn't terrible but you do notice it.
    Harley
