Anti-lock brakes on Ford and Dodge
Discussion in 'General Tow Rig Discussion' started by CK5, Mar 28, 2005.
  1. CK5
    I know in the late model GM rigs there is an anti-lock wheel sensor located in the hub, do the Ford and Dodge solid axle rigs have something like that also or is it located elsewhere?
  2. Shaggy
    Shaggy TRC Staff Moderator
    Los Banos, CA
    In the Ford it's in the diff housing in the rear, since it's a 3 channel system. The fronts on either truck should have sensors in the hub/rotor area. The Chevy uses a 4 channel system so that's why it needs sensors in each hub. No idea what the Dodge is using since I never really researched those trucks...
  3. CK5
    Welp, they are about a 100.00 bucks for the Chevy. :eek: I need to call the Stealership and get the part number so I can see what gmpartsdirect's price is.
  4. willyswanter
    Bakersfield, CA
    Ah reason 37 why I removed all the ABS stuff from my chevy... I have to say it was the worst ABS system I have ever have. Took me close to death on a few occasions when the truck was bone stock.
  5. jac6695
    jac6695 Well-Known Member
    Christiansburg, VA
    Steve, they usually just need to be cleaned. Dirt and crud get in there and can fool with the signal back to the ABS unit. Also, I have a couple here if you want to just throw a good used one in there. FYI, I have heard of GM VSS's (in the transfer case and/or transmission) getting dirty to the point of needing cleaned due to a bad signal generated, which will cause the transmission to not shift properly, and throw a code.
  6. jac6695
    Christiansburg, VA
    Oh, and they can easily be tested with a multimeter.
  7. CK5
    James
    Yes, let me know when I can pick one up. waytogo waytogo
