bad shutter
Discussion in 'Ford Powerstroke 7.3' started by POW/MIApowerstroke, Mar 20, 2007.
  1. POW/MIApowerstroke
    POW/MIApowerstroke New Member
    Beaufort SC
    My truck has a shutter when it comes back to idle. it will do it sitting still or if i am moving. it is just when the truck comes off rpms to and idle. the rpms do not drop, it is just a bad shutter. scaned the truck and got turbo boost sensor a circuit bad and ICP. i have replaced the ICP. didnt do anything. any information will help. thanks.
  2. musicmasterstravis
    Southern Michigan
    depending on the year, you have more then one sensor on each circuit, just plug in the comp. and start pulling plugs till the code doesnt show up. (Told by a 15 year experienced diesel tech)
  3. POW/MIApowerstroke
    Beaufort SC
    if i have a computer plugged into the truck and start unplugging sensors in the A circuit it wouldnt make the code go away would it? it is a hard code stored in the computer. i have an edge evolution programer. that is what is telling me the code. thanks again
