Boost pressure 4 2001 7.3
Discussion in 'Ford Powerstroke 7.3' started by sf_neoshomo, Sep 28, 2007.
  1. sf_neoshomo
    sf_neoshomo New Member
    sw missouri
    Hello all, can someone confirm what the local ford dealer told me concerning turbo boost being 17lbs. Seems really low to me.
  2. cumminspower572
    cumminspower572 Active Member
    Roscoe IL
    my father has see 30+ibs with his 7.3 with a banks kitwaytogo
  3. sf_neoshomo
    sw missouri
    Thanks for the info.
  4. 1999GMC
    1999GMC Well-Known Member
    Carmichael, CA
    Just talked to a buddy with a 2002 F-350 and without his chip he sees 16-18. With his chip he sees over 20psi.
  5. RamJetGMC
    RamJetGMC Active Member
    nj
    all i can add to this is i see 20 tops and i think the factory boots blow off at 37 psi
  6. PSDPOWER
    PSDPOWER Member
    Michigan
    I see 24-25 psi
    2002 f350 7.3L
    afe stage II intake
    edge evelution
  7. Dsl Truck Tech
    Dsl Truck Tech Member
    17 psi is correct. That is about the tops you will get without a programmer or chip. A programmer with remap your boost solinoid to let it build more psi before popping off.
