Brake controller for 05 2500hd
Discussion in 'Towing Equipment' started by gmcjimmy88, Mar 23, 2006.
  1. gmcjimmy88
    gmcjimmy88 Well-Known Member
    North Carolina
    I am looking for a good easy to use/setup brake controller at a good price. I just purchased a new Kuafman dual axle (dual axle brakes) 20 ft trailer and need to get a controller for it. Anyone have any good suggestions? Also looking for a good place to mount it as well. I would like to keep it off of the "kick panel" under the dash. Thanks for your opinions
  2. Brisk
    Brisk Well-Known Member
    Castle Rock, CO
    Tekonsha prodigy w/ the plug n' play harness is what you need. I got mine at RVwholsalers.com for about $100 shipped. I have used the Voyager and other controllers before and this one is by far superior.waytogo
  3. jksmich
    jksmich Member
    Washington
    I agree! I have the Prodigy and it is by far the best on the market. Easy to set up and use.
  4. FordCummins1
    Decatur, IL
    x3 on the Prodigy. Best bang for the buck out there.
  5. RockRig
    RockRig Member
    another Prodigy vote. I just upgraded to one and I'm impressed -> it's very smooth.
  6. Seventy4Blazer
    love my kaufman trailer and LOVE my Brakesmart. i wont ever try anything else.
    i have had ZERO issues with either one of them. you will be very happy with your trailer.
    also the brakesmart is now a bit newer than the one i have. it has a few more options.
    IIRC the website is www.brakesmart.net
    but i could be wrong. it will cost a bit more... but well worth it in my eyes.
    Grant
  7. MTMike
    MTMike Well-Known Member
    Billings, Montana
    Not to hijack... but what makes the Prodigy so superior? Does it work differently than others?
    I'm asking because i'm thinking of upgrading. I have a cheap-O $30 controller now and now that I have a new trailer with very good brakes my cheapo isn't cutting it.... stopping from highway speed i might as well be flooring the brake pedal and letting off every 3 seconds, even with the power dial turned all the way down.
  8. Burt4x4
    Burt4x4 Well-Known Member
    Modesto, CA
    3 types of controllers
    BrakeSmart the best on the market (so they say) and the most $$$$ This one taps into your hydrolic sytem and is suppose to be Top Shelf.
    http://www.brakesmart.net/
    Prodigy is enersha (sp?) controlled. So when you step on the brakes the slowing down feeling is what the controller is going off of to determin how much voltage to send to your trailer brakes. Some how this works real well accordig to all that use it.
    http://www.tekonsha.com/prodig.html
    Jordan is the one I bought. It is controlled by a small cable you hook to your brake pedal so as soon as you touch the pedal your controller is activated. I like that idea the most so I went for it and has worked perfectly on every trip so far.
    http://www.jordanbrake.com/
    Thoes were the top 3 when I was researching the net for info.
    Good Luck
    Oh I mounted mine on the bottom lip of that kick panel in the very center..so far it has never been in the way or made me think I put it in the worng spot so it works fine for me.
  9. 451Mopar
    451Mopar Active Member
    Aurora, Colorado
    Prodigy again, mostly because it's super easy to hoof up if you order it with the wiring harness for your truck. i think it is accelerometer (inertia) based, and has various boost setings depending on the trailer weight.
    It is also reasonably priced.
  10. rdean
    rdean Member
    Virginia
    Prodigy here. Dealer recommended it when I bought the trailer. Just plug in the harness. Not had any problems with it.
  11. CaliforniaK5
    CaliforniaK5 Member
    Add another Prodigy to the list. Love mine and have had no problems with it so far.
  12. moneypit
    moneypit Active Member
    prodigy here too. love it!
