Brand New AirDog 100 / 150
Discussion in 'Parts for Sale' started by BIgBadDodge, Apr 4, 2009.
  1. BIgBadDodge
    BIgBadDodge Member
    Rohnert Park, CA
    Brand new AirDog 100 or 150 (your choice) free shipping directly from Pureflow Technologies and LIFETIME WARRANTY for only $475.00 cheapest price anywhere.
    Most Compact System Available for the Pickup Truck.
    Only 7” L x 3.2” W x 10” H
    High Efficiency, Long Life Gerotor Fuel Pump
    Lower Cost Replacement Filters
    3, 5, and 10 Micron AirDog® Fuel Filters Available
    Relay Controlled Wiring Harness
    Low Fuel Pressure Warning Light Available
    Includes Wire Screen Water Separator
    Lifetime Waranty
    90 Day Satisfaction Guarantee
    The compact AirDog® provides the most effective technology designed specifically for diesel pickups to remove water, particulates, vapor and entrained air from diesel fuel. The AirDog® replaces the Cummins factory lift pump and filter system, and enhances the fuel delivery to the Powerstroke and Duramax with a commercial duty system.
    Your High Performance diesel engine demands higher fuel flows. Yet, higher fuel flows increase the vacuum at the fuel pump and agitation in the fuel tank. These factors generate additional air/vapor in the fuel system preventing your engine from producing maximum power and efficiency. Additionally, air/vapor can cause galling and pitting of the injector barrel/plunger assembly and also tip erosion.
    The AirDog® eliminates the air in the fuel that robs your engine of consistently greater performance and can also cause permanent damage to your injectors. The AirDog® also provides the fuel pressures and flows your diesel engine needs to produce maximum power, any time, every time!
    For serious performance seekers, whether you run a Cummins Turbo Diesel, Duramax, or Powerstroke on the daily grind or for weekend pleasure, the AirDog® has something to offer you!
    http://www.pureflowtechnologies.com/AirDog.htm
    BBD
  2. LOGANSTANFORTH
    LOGANSTANFORTH Member
    ohio and florida
    give ya $22.95 for it Scott.......rotflrotflrotflrotfl
  3. 1dieselsteve
    1dieselsteve Member
    mich
    you shouldn't advertise what your truck is worth!!!!!!!!!!!rotfl
