Calling all 2nd Generation Dodgers
Discussion in 'Dodge 2nd Gen Cummins 5.9 (24v)' started by saucier, Jan 26, 2008.
  1. saucier
    saucier New Member
    Dodgers let me see if I have this right. If I buy 2001.5 diesel 2500 24v with 33,000 miles in order to play it safe, I should take the following steps:
    - FASS fuel pump
    - juice/attitude (b/c it comes with a fuel pressure gauge, seems like fuel
    pressure gauges are just a little less than the edge system)
    - install a BHAF
    - install exhaust
    - keep juice/attitude off of level 3-5 in order to save life of transmission
    Are these the steps I should follow to promote longevity of the truck?
  2. Woods
    Woods Well-Known Member
    With 33K miles on the truck. Step one, get a VB/TQ for the trans if its an automatic. You won't believe how much better the truck will run. waytogo Step two exhaust & BHAF. Step Three FASS and Edge. Then try to keep tires on the truck. :D
  3. RJF's Red Cummins
    You don't *need* a FASS system. The stock lift pump should be able to supply enough fuel for a stock truck with the addition of just the Juice.
    What is most important is having the fuel pressure guage, that will tell you what you do and don't need.
    I would also reccommend a valve body at least, and likely a new converter also, as it will make the trans actually handle the power and last longer.
  4. DodgeManDan
    DodgeManDan New Member
    To play it "safe" if you just need to open the exhust and a freeflow intake like the BHAF. The fuel press.guage is a must if you dont do anything else you have to do this. I got 200K+ out of the stock tranny,and vp44 with no problems with only these mods.
