Can put hydrotex Hytorque-z in my g-56
Discussion in 'Dodge 3rd Gen Cummins 6.7 (24v)' started by John T Lippold, Aug 22, 2007.
  1. John T Lippold
    John T Lippold Member
    Gentlemen,
    I just purchased a ram 2500hd with a g-56 and a 6.7.Can run the hydrotex hytorque z trans fluid in the trans.It seems to be thicker than than the atf+4 that chrysler recomends.If not,whats the best synthetic atf that I can run in that trans.:confused:
    Thanks,
    John T lippold
    AKA 6.7HVN
  2. cjowett
    cjowett Well-Known Member
    great white north
    Why would you not just stick with the ATF like they recommend?
  3. Diesel Nut
    Amsoil ATF is perfect for the G56. I would recommend staying with the manufacturers weight oil. A thicker oil can cause more trouble than good.
