changed diff oil now g56 and it was nasty
Discussion in 'Dodge 3rd Gen Cummins 5.9 (24v)' started by ron monical, Mar 28, 2006.
  1. ron monical
    ron monical Member
    castaic ca
    changed my differitial oil at 7500 miles and it looked terrible. glad i did it i waited to 15k on my 03 and it looked worse. now onto the g56 has any one had the pto covers off. i cant tell what was used on the covers for selant or gasket and i was hopeing someone knew. dont want to make it to obvious i was in there cleaning up after the brizilians and get my warranty kicked i dont know for what but dont want to chance it. but want the filth out. thanks ron
  2. Seventy4Blazer
    hmm.. im neglecting my NV5600 and rear dif on this one... SOON!!! i promise!!
  3. Diesel Nut
    Amsoil Severe Gear 75W-90. You will love yourself for it. I did. I sell it because I use the stuff. Check my sig for more info.
  4. RJF's Red Cummins
    Ditto, in nearly every case people report a little less noise and smoother engagement of reverse and 1st with the Amsoil Syncromesh in the NV5600's.
  5. Seventy4Blazer
    is this for the trans or the dif?
    umm.. lets see... i need 9 qts for the trans and 5? for the diff....
    thats 140 dollars at the least... :doah:
  6. RJF's Red Cummins
    Your NV5600 uses Syncromesh 5W-30 trans oil. It holds 5 quarts. Your Rear end would need about a gallon of 75W-140. DO you have a posi?
    5 quarts of Synchromesh, $38.50 plus tax.
    4 quarts of Severe Gear 75W-140, $52.40 plus tax
    The gear oil would be cheaper if you prefer 75W-90 and or you don't have a posi and it's an open rear end.
  7. Seventy4Blazer
    K, i found out how much "Extra" the new cover i ordered adds. it will be just over 5 Qts, so have to buy 6.
    as for the 7 quarts of fluid in the NV5600... when i change the fluid i will be installing my fast coolers...
    looks like my 140 dollar guestimate wasnt too far off once shipping is added in...... :doah:
    as for posi, yes i have it but the factory does not required addatives for the AAM center section....
  8. strai8up
    strai8up Well-Known Member
    Middle Georgia
    are you saying that I need the 75\140 if I have the posi? and do I still need to use a posi addative?
  9. strai8up
    Middle Georgia
    blazer posted at the same time . I think he answered my question
  10. RJF's Red Cummins
    So the FAST coolers bump you up two quarts capacity?
    As far as the rear end, it holds about a gallon according to Amsoil's database.
  11. RJF's Red Cummins
    75W-90 if you don't tow heavy, 75W-140 if you are pulling heavy loads.
    Apparently you don't need an additive for your rear end regardless of the type of differential.
    Severe gear is fairly more pricey than Long life version, mainly because of extra additives, an additive for posi units being one of them.
  12. RJF's Red Cummins
    Looks like you are correct.
  13. Seventy4Blazer
    1 quart per side, i am doing both since i dont have plans any time soon for PTO.
    i tow HEAVY and if im not towing my right foot thinks its a race car... my brain knows its nothing of the sort... but they dont talk well together.... so the 140 weight is for me.
    and the cost of 140... well, it isnt... :doah:
  14. RJF's Red Cummins
    I know, thats why i didn't even bother with mentioning 75-90.:D
  15. strai8up
    Middle Georgia
    thanks for the info. I will stick with the 140 too.
