Damn it !!!
Discussion in 'Dodge 2nd Gen Cummins 5.9 (24v)' started by Hossbaby50, May 26, 2006.
  1. Hossbaby50
    Hossbaby50 Well-Known Member
    I found out today that my lift pump is dying. Now I am going to have to take the truck in and have the damn thing replaced. :mad: At least I have a warranty still. :cool:
    Why can't Dodge or Cummins pull there head out of there arse and fix this problem correctly. When this warranty is over I am going to have to get a FASS or something.
    Harley
  2. Torquer
    Torquer Well-Known Member
    Gresham Oregon
    Watch out for their 'fix'. They are now putting an in-tank pump in that many question whether it is an improvement because the fuel pressure is in the 5-7psi range at idle instead of typically 12-24 with the stock location lift pump. Only reason I'd go to the dealer is if the VP was dying because of this..............which may now be on it's way out depending on how long you ran it with a dead LP. Do you have gauges? How did you determine it was 'dying'?
  3. RJF's Red Cummins
    Relax a little, it could be the original one. Put a new one on and see how long this one lasts. You should get a considerable amount of mileage out of it. My original lift pump lasted about 100K, thats not bad IMHO.
    Just make sure you make it clear to the dealer that you want a replacement pump in the same spot, not the in tank setup.
  4. nevrenufhp
    nevrenufhp Well-Known Member
    Modesto, CA
    What's wrong with the tank one? Is it low flow?
  5. Torquer
    Gresham Oregon
    It shows lower pressure on the FP gauges from guy who have had it done. Dodge has been doing 'flow tests' to ascertain if the LP is bad instead of 'pressure tests'. I'll not debate flow vs pressure - anyone a fluid dynamics engineer? :popcorn:
  6. Mr. Big Ram
    Mr. Big Ram Well-Known Member
    vegas
    Why wait? :confused:
  7. RJF's Red Cummins
    Because his warranty would laugh at him if he asked for the FASS system instead and would probably still laugh if he said he would pay the difference. They just want to use a stock replacement.
  8. Diesel Nut
    Funny thing is the FASS 95gph pump is cheaper than the replacement. I talked to a guy who had a stock pump put on at the dealer out of warranty and paid like $600! I tlod him he got used and I would have sold him a FASS 95 for much less and install is so easy a monkey could do it (obviously, if I can anyone can!).
  9. RJF's Red Cummins
    IIRC, when my service contract replaced my lift pump it was $400.rotfl I didn't care, I wasn't paying for it.
    The problem is that service contracts do NOT want to mess with anything "performance." Anything that is not a stock style part is "inferior" and not worth the hassle to them. Yet, they love getting cheap aftermarket replacement parts if they can sneek it by you.:rolleyes:
  10. Hossbaby50
    I just got back into town.
    I have bought gauges but have not had time to do the install yet. I hooked up the fuel pressure gauge temporarily to see what my numbers were.
    9 psi idle
    2 psi wot :doah:
    So the lift pump is not dead yet but is dying for sure. I am going to take the truck into the dealer and have them check it out along with my cruise control since I have an extended warranty. I would like to do the FASS eventually but right now I don't have any money to buy one and if I installed one they would try and say it would void the warranty should something happen to the VP which I really can't afford.
    What are the pressure numbers for the new intank pump so I know what they should be? Thanks
    Harley
  11. RJF's Red Cummins
    Don't let them do the in tank pump, you should be able to at least request the stock LP in the stock location.
  12. Torquer
    Gresham Oregon
    Not sure about the in-tank. My stocker gives me 12-13 @ idle/cruise and pretty much won't go below 7-8 @ wot.
  13. Dave@BD-Power
    Abbotsfordf BC
    I agree with JRF about the in-tank one, the dealer does not take into consideration than you are running a chip so when the in-tank pump takes a dump you are lift with pulling the tank...again!
    Warranty or not it is a pain in the butt... for those of you that were not given the option the BD Auxiliary lift pump kit works with the in-tank setup to assure it does not fail.
  14. Hossbaby50
    Currently my truck is all stock (no chip) but someday down the road I will be doing a SMARTY or Edge EZ.
    The dealer I am taking it to is a Chevy Dealer. That is where I bought the truck and that is where I must take it to for my warranty if possible. I will try and pull one over on them and get them to do the lift pump in the stock location.
    Thanks
    Harley
  15. RJF's Red Cummins
    Your service contract wants to to have the work done at the dealership you bought it from, AND it's a Chevy dealer?
    When I had mine I could take it to any shop with a business license and ASE certified.
  16. Hossbaby50
    I think I can take it other places but the contracts says if possible you should take the truck to the purchasing dealer. If you can't take it there then you need to call #............. and they can tell you were to take it.
    I would bet that when the Chevy dealer gets it they will probably just send it over to the Dodge dealer to have the work done.
    Harley
