DC approved oil but use cheap oil
Discussion in 'Dodge 3rd Gen Cummins 6.7 (24v)' started by 2007CUMMINZ, Nov 21, 2007.
  1. 2007CUMMINZ
    2007CUMMINZ Well-Known Member
    Tarheel State
    I have got a real question? If these 6.7L engines are going to be requiring oil changes every 2000-3000 miles why are we concerned with using the best of oils?
  2. nainoapak01
    nainoapak01 Well-Known Member
    6.7 oil changes are 7500 miles not 2000-3000, read the owner manuel:stir:
  3. 2007CUMMINZ
    Tarheel State
    I am aware of the requirement of 7500 oil changes but whe your service engine light comes on every 2k-3k what else can you do?
  4. fubar
    fubar Member
    Re-set the light with the DIC. waytogo
  5. MPC 1
    MPC 1 Member
    Central Coast Calif.
    I have 6700 mi. on my 6.7 , and have towed a 34 ft. livingquarters horse trailer ( aprox. 15,000#). The change oil light came on just after 5000 mi. I am an amsoil dealer and will be changing it over at the next service. In both of my last trucks; 2000 ctd,qc,drw,5spd.,gear vendors o/d,banks power pac,&banks brake. & 2005 dmax, Banks 6 gun big hoss bundle,bd exhaust brake , I have used amsoil
    with oil changes between 10,000 - 15,000 miles, but even amsoil is not recommending extended change intervalls on the new ultra low sulfer motors.:mad:
  6. 2007CUMMINZ
    Tarheel State
    This past oil and filter change I also went to Mobil 1 syn. but I do not plan to go way over what is recommended. Since my G30 flash my service signal has not come on. I am feeling better about that.
    I plan to install a bypass filter soon.
    My personal opinion these 6.7Ls need a bypass filter no matter what you do with it.
    CumminZ
  7. Diesel Nut
    This is for 2 reasons. The new emissions compliant oils saw net reduction in TBN from 12 to 10, so the oil cannot neutralize as much acid as before. This is a major part of extended drains.
    Next, we are going increasingly towards heavy EGR usage, which will create more acid in the crankcase then a non egr motor.
    These 2 factors are the main reason why Amsoil does not support extended drains on 07 up emission motors without the use of a bypass filter and oil analysis.
