Do you plug your diesel in?
Discussion in 'General Tow Rig Discussion' started by RJF's Red Cummins, Apr 9, 2005.
  1. RJF's Red Cummins
    If the diesel is equipped with glow plugs, the 110 keeps them hot correct? If this is correct wouldn't this have a longevity effect on your glow plugs? I plugged my Dodge in once but after about 15 minutes I could smell something slightly burning, I immediately unplugged it.
  2. BadDog
    It does not keep the "glow plugs" hot, it connects to a heating element that keeps the block warm for really cold seasons (like near or below 0*F). Without the heat it can be difficult or almost impossible to crank a diesel when very cold.
  3. RJF's Red Cummins
    Oh, ok. So it's a competely different heating system, got it.
  4. Stomper
    Stomper Active Member
    It heats the coolant in the engine.
  5. MNorby
    MNorby Well-Known Member
    its a block heater. Also the cummns doesn't have glow plug but rather a heat grid to heat the intake when starting.
  6. joez
    joez Well-Known Member
    New Lenox, Illinois
    I plug mine in whenever its below freezing, or else its a total PITA to start. I need a new starter desperately, but dont want to waste money on a motor that i am just going to yank out for something better.
  7. mudskipper
    mudskipper Member
    I have started my 2003 CTD in weather of about -8F without it being plugged in while in northern Wisconsin. I use to plug in but rarely do anymore.
  8. MNorby
    Mine will start in sub 0 weather without being plugged in but it runs rough for a bit till it warms up but if I plug it in with the same conditions it runs alot smother and warms up faster
  9. RJF's Red Cummins
    How does the grid heater work exactly? I have heard of this before on the cummins over at TDR. Mine seems to cycle for a few minutes when cold, I can watch the voltage guage move around.
  10. FordCummins1
    Decatur, IL
    Its basically a grid of wires that has a current running through it. As the current passes through, it heats up the wires, as well as the surrounding air in the intake. So instead of cold air flowing into the motor, heated air is entering.
  11. RJF's Red Cummins
    Oh, ok. I've had little house heaters like that. :doah: It would seem to me that glow plugs are a better warm up system, but maybe not.
  12. MNorby
    In my experience last winter our 97(?) powerstroke work truck wouldn't start and my dodge would so I had to use my personal truck to jump it when it go way cold. Heck, I even had to jump start a couple semi trucks too. I think the heater grid works pretty well.
  13. DBlazer
    DBlazer Member
    Haslet, Texas
    I pug mine in whenever it is cold. Simply because I don't like to be cold. [​IMG]With it plugged in, the heater comes on warm[​IMG] and I am all cozy!!!
  14. kennyw
    kennyw Member
    Stevens Pass
    Good thing it never gets cold in texas rotfl
