If so what brand/model do you have and what kind of riding do you do? I've got a 2004 Polaris Scrambler 500HO 4x4 and use it mostly for farming. Plan on taking it up to the mountains sometime this summer and try out the same trails I snowmobile on during the winter.
Prepare to drool. I have an 88 yamaha terrapro for in the cemetery. It has the PTO (only made 1 year) with a 48" pull behind field mower (2 point hitch hookup) and a 100 gal tow behind sprayer tank with a PTO powered pump. The 350cc 4 stroke motor may seem small but in low range I have pulled a 500lb hydraulic dump cart loaded with half a ton of dirt with it. It's all shaft drive with an unlocking rear differential so turning is easier when you have some weight on the rear axle tow point. I use it for everything from hunting, to hauling dirt/mulch/whatever, mowing the lawn/cemetery, settling graves with the water tank. And that water tank comes in handy when we light the burn pile.
We've got a 99 Polaris Xplorer and 02 Sportsman 700 twin. In low range they can pull a lot of weight. We use them around the ranch basically doing the same stuff, spraying, hauling dirt, etc...
