Dodge mid 80's axle ???
Discussion in 'Dodge 1st Gen Cummins 5.9 (12v)' started by yellowxj, Jul 25, 2005.
  1. yellowxj
    yellowxj Active Member
    Whats the difference in width of the 3/4 ton axle and the 1 ton axle? Are the spring pads the same width apart? I've got a D60 from a 89 3/4 ton now but wanting to bolt on a dually axle. TIA
  2. DWitcher
    DWitcher Well-Known Member
    Bakersfield CA.
    They should have the same spring pad width. There is always the tape measure method :D
  3. yellowxj
    still havent found the dually axle I was looking for but did find a 94 2wd dodge axle that has the same measurement for spring pads as my 89 axle...so it seems like the same axle from 78 to atleast 94 will work for the springs...the 94 axle is 73" wide the 89 is 65"...give or take...spring pads are 43.5"
