drag times?
Discussion in 'Competition' started by gda1988, Dec 22, 2007.
  1. gda1988
    gda1988 Member
    jupiter,fl
    hey guys, i have a 2005 dodge 4 door 4 wheel drive with a 5.9! i was wondering if anyone would know what it would run with the mods i have done to it? i have an air riad intake and a diablosport programmer! i ran it at the track when it was bone stock and my best time while spinning was a 16.3! i was wondering if anyone would guesstimate what time this truck would be potential of?? thanks for your help!
  2. Diesel Nut
    I would say with the Diablo you should be into the 15's. Now, a 4wd launch will help get you down lower, but the stock input shaft on the transmission will not like that very much at all. If it breaks, you are into a transmission teardown.
    For now, you can work on your 60' time by practicing. Reducing your 60' time will reduce the overall ET a lot. For now, you will be working with 2wd until the transmission gets upgraded. Want to go faster once you have traction? Install a Trans Go shift kit or a complete Valve Body!
  3. gda1988
    gda1988 Member
    jupiter,fl
    damn!! only 15s?the truck was sooo slow when it was stock now i can keep up (from a roll) with a camaro but only 15s thats slow but i guess fro a 7000pund truck that aint too bad lol
