Dually disc brake conversion
Discussion in 'GM Diesel 6.5' started by campcook, Jul 29, 2005.
  1. campcook
    campcook Member
    I have a '99 gmc dually with drum rear brakes. I found a rear end out of a 2004 dually with disc brakes and was wondering if anyone had some insight.
  2. Joey D
    Joey D Member
    I think you will need the master cylinder to go with it or at least a larger one.
  3. Brisk
    Brisk Well-Known Member
    Castle Rock, CO
    It may involve some modification of the ABS as well
  4. campcook
    campcook Member
    dually brakes
    Do you know anyone who could let me know for sure. What kind of mods to the ABS, physical or computer?
  5. Joey D
    Joey D Member
    Does the rear have a abs sensor on it or is it at the t case? I don't think my 98 has one at the rear axle and I don't think my brothers 01 does. If thats the case it will work no problem. I know guys swap rear discs in all the time and never touch the master but the dual piston calipers are huge on the HD's and the resivior on the master may not be up to it.
  6. campcook
    campcook Member
    I just realized that the axle I purchased is out of a single wheels truck. I hope it will still work.
  7. myclone
    myclone Active Member
    I made the same mistake and found out the hard way that the SRW and DRW axles wont interchange (leas in my application). The spring mounting pads were in the same location but the width of the entire diff as well as the hubs was off by quite a bit. I lucked out since I got the replacement rear diff dirt cheap and was able to resell it for what I paid for it though.
  8. Joey D
    Joey D Member
    What did you pay for the axle? Want to sell it?
  9. campcook
    campcook Member
    I'd love to sell it! I,m here in Martinez CA. Where are you?
