electric brake wiring?
Discussion in 'Towing Equipment' started by kustom71, Jul 6, 2007.
  1. kustom71
    kustom71 Member
    south jersey
    There are two wires coming out of the backing plate for the electric brakes.
    I understand 1 goes to the blue wire from the controller and the other is basically a ground but should I wire it to the ground wire in the 7 pin plug or just ground them to the trailer???
    Just want to be sure so I can finish!
    Thanx
  2. duckmanquacker
    Lago Vista,Tx
    if you have the white ground lead atatched to the trailer frame then mount the brake ground to trailer frame as well. if your ground wire is routed to all components do the same for your brakes.waytogo
