End Links
Discussion in 'Ford Powerstroke 7.3' started by NavyTech, Sep 15, 2006.
  1. NavyTech
    NavyTech Well-Known Member
    pa
    I believe the bushings in the End Links on the anti swaybar are worn out. I went down to the Ford Dealership and they said you have to buy the whole End Link instead of just the Bushings. Is there anywhere you know of that you can get these instead of paying $55 for each End Link or even possible get them in Urithane
  2. 00F250
    00F250 Active Member
    Warren, Oh
    I don't think you can get just the bushing. I could be wrong though. I just replaced my end links a couple days ago. Mine were the same price and super easy to replace, but I used an impact to change mine. Just be aware the sides are different, the pass side has a hat looking device protecting the bushings. My guess to keep the heat away. My new passenger side bolt was a .25" to long and had to be cut down. Not sure if it would fit fine on a gasser versus a diesel. I think the bushings would have to pressed out and in though.
