Enngine Won't Shut Off
Discussion in 'Ford Powerstroke 7.3' started by BurbLover, Oct 13, 2006.
  1. BurbLover
    BurbLover Well-Known Member
    SW Missouri
    I have a 96 PSD with the turbo saver unit installed. About a month ago, it started to not shut off. This has really become a PITA as the other day my truck ended up running almost 6 hrs before I found out it was still running. I was wondering if anyone else ever had similar issue with one of these units.
  2. BurnedBronco
    well, what controls the turbo saver? it is obviously getting a false reading keeping the truck running.
  3. rocknbronco
    rocknbronco Well-Known Member
    Flat Top Mtn,Tn
    its gotta be the timer
  4. BurbLover
    SW Missouri
    I'd start to look at things, but I have no idea what to look at since this unit was on the truck when I got it.
    I know some times the truck will shut off just by shutting the door hard. Kinda like a loose wire or something needs jarring.
    Anybody have any idea where (location) I can find this unit and what it even looks like?
    TIA!!
    BTW, my initial thoughts were bad temp sensor or ignition switch.
  5. bigbaddiesel
    bigbaddiesel Well-Known Member
    uhmmm i forgot give me i minute
    try to unhook the turbo saver and see how it it runs check wiring and connections on it maybe a bad heat sensor on the turbo
  6. BurbLover
    SW Missouri
    I am going to try and do that this week. Too many things going on the hit all at once. Short version...Found out yesterday I leave in about a month for Kuwait for a year. I need to get ready to move, load, and move in about 2 1/2 weeks.:doah:
  7. bigbaddiesel
    let us know how that turns out and im sure i speak for everybody on here i wish you the best of luck on hope you are safe in kuiait... my uncle just returned form baghdad and the stories do not sound fun
