F-450
Discussion in 'Ford Powerstroke 6.4' started by danoren, Oct 31, 2008.
  1. danoren
    danoren Active Member
    WEREVER I CAMP
    Does the F-450 pickup have the same diesel like the F-250/350 Diesels?
    If so how come the F-450 has much more pulling capacity?
  2. cumminspower600
    cumminspower600 Member
    Roscoe, IL
    450
    yes they have the same motor as the other f series. the increased towing capacity comes from the suspenson and stronger axels.
  3. 4054x4
    yup... same motor, just a stronger truck that can handle more weight; stiffer springs and whatnot.
  4. strictlyv8
    strictlyv8 Well-Known Member
    Miami, Fl.
    It call haul more because it's prettier.
  5. Bourdon1350
    Bourdon1350 Well-Known Member
    Weatherford, Tx
    Thats a dumb question...
  6. strictlyv8
    Miami, Fl.
    The dump questions are the ones that go unasked in my opinion.
  7. jake
    jake Well-Known Member
    There are never dumb questions, only dumb answers.
  8. 1tonpower
    1tonpower New Member
    cape cod, mass
    the 4.88 gears have a lot to do with it
  9. mbwagoner
    mbwagoner Well-Known Member
    Paso Robles, CA
    was reading the rest and was thinking gears, gears, gears. Factory specs on pulling ability all comes down to the ability to get it moving. Pulling power can be made with torque or gears. Then they (hopefully) add a big enough frame to support it and brakes to stop it as well.
  10. bubbamcnasty
    bubbamcnasty New Member
    Yeah, the axles in my 450 are massive. 4.88 are great for towing, horrible for highway mileage.
    also, the 19.5 tires, 10 bolt axles also help.
    As for stiffer springs, my ass. Put my 8000lb gooseneck on it, and it squatted a good 2 to 3 inches.
    Now running air bag overloads, inboard mounted, full custom leveling valves...oh yeah, and 22.5 Alcoa's.
    pulls like a train, and uses about as much fuel as a locomotive.
  11. john12121
    john12121 Member
    US
    A radius arm suspension setup called "Wide-frame monobeam" is a wide solid axle with coil springs that increases the pulling capacity of F-450..Rear-leaf spring are kept 8 inch longer with carefully tuning with a fifth-wheel hitch which provides 24,500 pounds of pulling capacity...
  12. Eastern
    Eastern Member
    New York
    You guys are also forgetting that Fords comm. trucks (cab and chassis and some pickup models) come through defueled. Check the HP specs. @ Fords web site. The new 6.7 is rated @ 400 HP but comm. trucks are only 300HP. Just my $.02
  13. caissiel
    caissiel Member
    Canada
    Towing capacity for me is based on cooling capacity, axle capacity, and braking setup. Due to HP detuned, larger wheels, and higher gearing adds to capacity. Our trucks are designed for the worst conditions, so driver attention to driving style is much more important then stated capacities. I towed a 5k trailer with a 2.5k trailer cap. truck very sucessfully for 3 years and never hurt the truck until I did an emergency stop and 35lbs in the rear tires allowed the tires to turn on the rims. A local guy pulls a 14k 5th wheel with an F450 with 35lbs air in the 4 rear truck tires because the truck is to rough. I told him I would not go one mile with that setup. I prefer SRW with 80psi in my rear tires.
