My chevy 06 has a mounted electric brake controller connector under the dash , need recommendation which electric brake controller will work the best with this set up.. Is there one available that just plug in .... ????? tx
usually there is a pigtail that came with the truck... with 4 wires that you splice into your new controller when you get it. then you can just plug it in. or at least that's the way my Dodge was.
they also have prebuilt cables that go between the prodigy and your chevy. you dont need to splice cables that way, very clean. got one in the wifes yukon and install was about 10 minutes, mostly deciding where to put the controller.
