FASS is leaking
Discussion in 'Dodge 2nd Gen Cummins 5.9 (24v)' started by Citizen Rider, Sep 5, 2007.
  1. Citizen Rider
    Citizen Rider Member
    I bought a 95/95 FASS system from Diesel Nut back in May and got it installed in June. The other day i was walking to my truck leaving work and theres a big wet spot right under the FASS. I looked under the truck and the whole drivers side from the back of the cab to the bumper is covered in diesel. And the FASS is soaked in diesel.
    What the heck is goin on? Has this happened before?
    Justin
    Well, where is it coming from when the pump is running?
  3. Citizen Rider
    Not sure. Theres diesel all over the pump, and under the bed/frame. I have a feeling its comin from one of the fittings, but not possitive. Im gonna spray it down at work tomorrow and take a look from the oil pit.
  4. Diesel Nut
    Spray it down, with a good degreaser, make sure the unit is dry, and see if you can locate the leak. IF its not a loose fitting, and is a warranty item, I am sure you are still in the warranty, and we'll get you taken care of. Let me know what you find.
  5. RJF's Red Cummins
    If it's leaking good enugh to soak the back half of the truck with fairly fresh fuel than you should be able to find a drip of some sort.
    This is off the wall, but if you have access to a super dusty road or field, get some dust flying under that truck. You'll then be able to clearly find the shiney spot with fresh dust free fuel. Works everytime with equipment in the field for me.
  6. Citizen Rider
    Turns out to be where the 2 halfs of the body are attatched. Theres 4 allen head screws holding it and its seaping between the 2 bodies. warranty i hope?
  7. Diesel Nut
    Call me, we'll get it taken care of.waytogo
  8. frdslar
    frdslar Member
    new fass
    hey diesel nut i was wondering about a fass pump for my truck
    would i need a 150 or 95
    or what i need some info
    Thanks
  9. Diesel Nut
    Late night tonight in the shop, I will PM ya in the AM!
