Fass or Air Dog?
Discussion in 'Dodge 2nd Gen Cummins 5.9 (24v)' started by ram02, Mar 19, 2008.
  1. ram02
    ram02 Active Member
    I'm going to add an after market fuel system to my truck.Have read and talked to alot of people about the Fass system.I saw the Air Dog system advertised in Diesel power.Anybody running this system? I would like to know the pros and cons of both systems.Just trying to make the best choice.
  2. Nitelord
    Nitelord Well-Known Member
    SE Pennsylvania
    I like the Air Dog. Life time warranty, and less money. waytogo Almost $150.00 diff.
    How it works appears to be the same. In fact I believe the replacement (fleetguard) filters are the same #.
    I haven't received my Air Dog yet, but that filter thing is something I'm looking onto.
  3. ram02
    ram02 Active Member
    Thank you I appreciate the info.Anybody else got anything?
  4. Nitelord
    SE Pennsylvania
    Side by side pic
    Here is a pic of a side by side comparison of FASS 150 and an Air Dog 100.
    This photo was shared with me by a good friend, Charlie waytogo. Awesome guy and has a great enthusiasm for anything Diesel.... He's the owner of Air Dog.
  5. Nitelord
    SE Pennsylvania
    Side by side
    Here is a pic of the FASS and Raptor (fuel pump without the filters)
    Again, the credit for the photo goes to Charlie.
  6. Diesel Nut
    We stick with FASS. Had nothing but great luck with them and they are on the ball if I need something. The comparison pic on the full systems is a bit misleading. If you compare the smaller 95 series pump and the Air Dog you will find they are much more similar in size. The photo shows the larger 150 series pump, which is what I have on my 06.
  7. Nitelord
    SE Pennsylvania
    Sorry, Don't want to mislead anyone. I have a Air Dog 150 coming soon. I'll see if I can get a comparison.
    Is FASS thinking about a lifetime warranty? Any rumors?
  8. ram02
    ram02 Active Member
    So,they both pretty much are identical,the only difference would be the air dog is cheaper? Does air dog offer an adapter to move my fuel pressure sending unit to the back? Thanks for the pics and everyones feed back.
  9. jp8819
    jp8819 New Member
    Airdog 150 is same as size as a 100 though so size wise it is a smaller unit plus lifetime warranty and 1/2 inch lines. love mine with no problems in 2 years.
  10. stumo
    stumo Member
    lynnwood wa
    i have the fass fuel system and was wondering if anyone knows where to get the fitting to hook up my fuel pressure sending unit. my kit came with a L fitting and no way to hook it back up
  11. Diesel Nut
    there are a couple ways to do it. We use a T fitting that goes right into the fuel line about 2 feet back from the injection pump and it works very well. You can also make one from stuff at the hardware store. 2 barbed hose fittings, a T and a 1/4npt to 1/8npt reducer and you have it!
  12. lukesdiesel
    lukesdiesel Member
    NC
    I sale both and I still prefer the Fass. I have had fewer issue with Fass as far as holding pressures. waytogo
  13. ram02
    ram02 Active Member
    Thanks to everyone who gave feed back and opinions on this.I'm going with the FASS system.Dont know who I'm gonna get from yet though.
  14. Diesel Nut
    Just keep in mind that FASS is on a similar program as Edge. Unilateral pricing. If someone tosses you a low low price beware, you will not get the lifetime warranty with it, and likely the dealer is not an authorized dealer.
  15. lukesdiesel
    lukesdiesel Member
    NC
    100% Correct
  16. ram02
    ram02 Active Member
    Thanks for that information about the warranty.I'm thinking of contacting diesel nut and getting it from him.
  17. Diesel Nut
    I am here if you need me!waytogo
  18. Tec
    Tec Member
    Denver,CO
    I just finished up my Airdog 150, I'm pretty impressed in how much quieter my truck runs now. I see 17-18 psi at idle and have not been able to drop it under 16psi on level 5 on the juice.
    As fare as the pressure gauge, I used the one that came in my Edge kit for my truck, The Airdog has a port in the case for one. Just had to cut the juice harness and extend the plug leads to reach the middle of the truck.
