Firestone air bag help
Discussion in 'General Tow Rig Discussion' started by INTERCEPTOR, Jun 10, 2005.
  1. INTERCEPTOR
    INTERCEPTOR Active Member
    I have a set of firestone airbags for my F350drw. Well they started to leak were
    the plastic line goes into the housing. Does anyone know where to find a rebuild kit for the airbags all I need is lines and the brass bushing that conect every thing to the bags.
    Thanks
  2. DWitcher
    DWitcher Well-Known Member
    Bakersfield CA.
    Are you talking about the fitting into the bag or the airline into the fitting leaking? Do your fittings have compression fittings that use a open end wrench or are they the quick connect style that push in and lock. Either way try a Truck shop or an RV store for fittings. If you are using quick connect try pushing the air line in futher.
