Fuel Pressure Gauge
Discussion in 'Dodge 3rd Gen Cummins 5.9 (24v)' started by 07MegaCab, Nov 4, 2007.
  1. 07MegaCab
    07MegaCab Member
    Williston, Noth Dakota
    Do you need to put a fuel pressure gauge on a 07 CR CP3 or is that just the ones with the VP44
  2. Duluth Diesel
    If you begin to bomb that truck, fuel pressure is very helpful to have. As your fuel demand increases, your factory pump will not be able to keep up. You aren't nearly as likely to damage your CP3 pump as you are a VP44, but the lift pumps are equally wimpy and should be monitored IMO.
    -Chuck
  3. Eric @ ATS
    Eric @ ATS Member
    Westminster, CO
    I agree. Better yet, you may just want to go with a rail-mounted lift pump and bypass the stock pump completely. Then you don't have to worry about the stock pump failing on you, and you'll have the volume capabilities on tap should you decide to start playing
