gcwr for 3500 dually
Discussion in 'Dodge 3rd Gen Cummins 5.9 (24v)' started by Trinitytrucking, Mar 12, 2007.
  1. Trinitytrucking
    Trinitytrucking Member
    long island , NY
    whats up guys ,,this maybe a stupid question ,,but what is the GCWR-GROSS COMBINED WEIGHT RATING when pulling a trailer i searched and couldnt figure it out ,,,,thanks in advance
  2. 2007CUMMINZ
    2007CUMMINZ Well-Known Member
    Tarheel State
    What year model?
    06' 3500 dually = 23k.
  3. Trinitytrucking
    long island , NY
    ok,,so if i add airbags ,,its helps by 5000lbs,,is that tru ,,i heard that from somone,,,????
  4. 2007CUMMINZ
    Tarheel State
    Gcvw
    Adding gizmos to your truck (bags, springs, etc.) has nothing to do with your GCVW. That is set by the manufacturer. The gizmos just helps your peace of mind.
  5. Trinitytrucking
    long island , NY
    ok,,so i'll still get my air bags so to soften up my ride a lil bit
  6. RJF's Red Cummins
    They are not going to "soften" the ride, mushy overloaded springs are soft. Air bags are going to remove some of the weight and pressure off the springs, letting them flex firmer.
  7. Trinitytrucking
    long island , NY
    ok,,so when the flex is taking uot,,isnt it not going to bounce around as much when loaded ,,also ,,when loaded the airbags will keep my truck from sagging in the rear
  8. Full Pull
    Full Pull Well-Known Member
    Lakeland FL
    yes they should bring your truck rte up.
  9. jimnbubba
    jimnbubba Member
    winter in AZ summer northwest
    06' dually 3500 CTD w/3.73 rearend 21000
  10. Trinitytrucking
    long island , NY
    thge 3:73's are lower,,,i have the 4:10's
  11. Seventy4Blazer
    airbags will smooth out the ride if you have them adjusted up to factory ride heigh. if you go more than about an inch lower you end up running the jounce bumpers onto the secondary packs. this makes for a harsh ride. doesnt hurt anything but the back.
    i love my ride rites. just need a compressor system for them... make life even easier.
    Grant
  12. cummins4x4
    cummins4x4 Well-Known Member
    Waller, TX
    check out the tow guide @ the dodge website.
  13. whiskey
    whiskey Member
    The higher the number the lower the gear ratio..waytogo :eek:
    whiskey:popcorn:
  14. cummins4x4
    Waller, TX
    well, i meant to find out about his GCVR and whatnot...it let's you pick your truck and then shows you all the numbers :)
  15. MrTow
    MrTow Well-Known Member
    Yeah that's what I thought too...WRONG. Makes it worse. :mad:
